Swivel seat security (3 Viewers)
Two on Tour
10,434
52,030
Elddis Autoquest 175
Can I ask, did fitting simply involve drilling a 14mm hole?
Yes, and to stop it being lifted up to get a disc cutter to the pin, I glued a 6mm thick washer to the pin.
http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=112056814537
68c
Oct 22, 2019
1,835
2,836
Southampton
2001 Pilote 270
Can't they just unbolt the seat and swop with the unlocked passenger seat, only four easily accessible bolts.
Jan 27, 2018
2,707
2,171
Northampton
Rapido & Bongone
Use as one line of defence, castle defence mentality. Or another effect persuade them to move on to an easier target. Always keep one line of defence hidden (don't tell anyone about the 3 pigmies with poison darts ive hidden in xxx?) Can't tell you where.
Feb 20, 2017
861
2,471
Kent
Bailey 75-2
Tugger now Motorhome
I have washers under my Patriot so as to not allow cutting from underneath. I suspect it will just spin with an angle grinder attack. You need the short shank version. The longer version is for use with a chain.
Feb 19, 2020
1,451
1,606
North Ayrshire
Adria Matrix 670SC
Yes it would spin and It’s a good line of defence and deterrent but an angle grinder would go through the metal plating of the seat base like knife through butter
Two on Tour
10,434
52,030
I looked at the practicalities of your statement of removing the Patriot security lock with a cordless grinder and I feel that at least in the way I have fitted mine that the removal with a cordless grinder are unfounded.
I own a Dewalt cordless grinder, the choice of most would-be thief's so offered up my grinder in many positions to try and get to the rear of the Patriot security lock to cut through the seat base plate as you suggest can be done and as you can see from the photos that this is not possible. So although you could cut up the sides of the lock, I'm happy that the rear can not be accessed.
Jan 19, 2014
9,431
24,902
Derbyshire
Elddis Accordo 105
since 2014
Impressive ?better than our pad lock underneath and high vis too. Ordered one off ebay £38.61 sportsbikeshop seller ?
Feb 20, 2017
861
2,471
Kent
Bailey 75-2
I located mine so when I had the seat turned I could move the seat where I need it. You would have to make a large diamond shape cut in the base to remove the lock. My idea was really to slow them down and make them have to make considerable noise doing it. I have another idea as well - a long shank quality padlock (Ingersoll Impregnable) through the steering universal joint that interferes with turning the wheel and again difficult to get to with an angle grinder as both sides of the shank need to be cut and it is behind the pedals. The shank in the picture is normally to the back of the joint.
Feb 19, 2020
1,451
1,606
North Ayrshire
Adria Matrix 670SC
I located mine so when I had the seat turned I could move the seat where I need it. You would have to make a large diamond shape cut in the base to remove the lock. My idea was really to slow them down and make them have to make considerable noise doing it. I have another idea as well - a long shank quality padlock (Ingersoll Impregnable) through the steering universal joint that interferes with turning the wheel and again difficult to get to with an angle grinder as both sides of the shank need to be cut and it is behind the pedals. The shank in the picture is normally to the back of the joint.View attachment 370480
padlock on the steering colum
Fair point. :giggle:
Wombles
10,833
11,216
SW England
A few years now
Jan 19, 2014
9,431
24,902
Derbyshire
Elddis Accordo 105
since 2014
Why is the storage bracket shaped in this way? Is it to clip on to a motorcycle somewhere, no instructions with it and the hole is a bit big for a screw. I found the cheaper one at XL moto by Googling for photos of the bracket ????
Jun 8, 2019
4,931
18,760
Bexley Kent
Given up Motorhoming
May 2019
Just looked they are now £43.99☹️
Apr 22, 2018
6,843
12,620
Herts.
Adria Coral lowline
Wombles
10,833
11,216
SW England
A few years now
Not sure if I’m doing it wrong, but lock is £49.99. Reduced to £42.12. Plus £3.95 postage. Then 10% off but is still a total of £43.66
There were two listings & looks like the lower price one is out of stock now as it did have a low stock warning :( Ours went through & confirmed by email but will wait & see if we get it or it was an error.
ORDERED PRODUCTS:
Oxford Patriot Brake Disc Lock
1 x £24.41
Specified delivery time: 2-6 working days​
Products​
£24.41​
Home delivery​
£3.95​
PayPal​
£0.00​
Voucher Code:​
-£2.44​
Total
£25.92
Apr 22, 2018
6,843
12,620
Herts.
Adria Coral lowline
Ahh. This one.
now out of stock.
I got one from Moto Central for £38 inc postage.
Jan 19, 2014
9,431
24,902
Derbyshire
Elddis Accordo 105
since 2014
I'll have some spare plate washers if anybody wants one, just looked on ebay. 4 QUID EACH! And only 3mm thick ? think mine are 4mm
They're M10 so need drilling out..
PM me ?
68c
Oct 22, 2019
1,835
2,836
Southampton
2001 Pilote 270
A lot of bike disc locks have a coiled cable that is clipped into the lock and the handlebar grip to remind the rider it is there, may be the hole is for the clip.
