Remap or not - pre adblue euro 6 Fiat (2 Viewers)
May 2, 2014
2,255
4,617
Washington
Hymer B 584DL
17 years + 35 tugging
Mine is a 2017 150bhp 2.3
Quite a few people with these, both on this site and elsewhere, find them either underpowered or too high geared. Mine certainly is compared to my previous 2014 150bhp Ducato which flew along motorways without the need to change down on hills.
Has anybody any experience or knowledge of remapping these particular engines? There are many companies listing them and showing expected performance figures.
robmilton
28
51
Fiat Ducato Bessacar
Hi, i would give Celtic tuning a ring and have a chat with them, they will come to you to do it, ours is an earlier 2.8 jtd but the remap has made it a different vehicle and so much easier and quieter to drive, and on a trip round South Wales recently it was giving near 30 mpg. If your not happy within 14 days they will put it back to standard foc.
1,453
1,292
Bury
Pilote G650L
Three years
I used Celtic Tuning and was very happy with the result. But it appears from this thread that I could have saved the money by just getting the ECU software update to v32, which appears to give similar results. 😐
3,518
9,348
The salty bit of Hampshire
Carthago Compactline
Since 2017
My 2016 Euro 5 engine in 150bhp spec has returned a whisker under 32mpg on my Carthago 138 Compactline A Class over the two years since I acquired it and that is running at it's plated weight of 3500Kg. I doubt it's worth fiddling with (If it ain't broke...) to try and eke another mile or two and might mess it up. My 2016 Majestic 125 with the 150bhp Euro 5 Pug engine which ran at just under 3300Kg produced virtually identical figures over a two year period.
93
111
Falmouth
Ducato PVC
3year
I suspect it doesn't give the same results, but it seems to be better than it was and I was suggesting it might be 'good enough'.
Joc
Jul 5, 2018
38
71
Bluntisham, Cambridgeshire
Adria Matrix 670 SL
Since 2018
In front of the gear lever, it holds gears longer before changing up or down, essential when driving in mountians.
Thanks for that Lenny (y):giggle:. I actually looked in the handbook :whatthe: and found the reference to the "UP" function. Wasn`t very informative as to what it actually does! Previously, when mountain driving, if the gearbox was constantly shuffling up and down, I`d wait `til it shifted down then flip the gear lever over into manual, this forced it to hold that gear. Worked for me but I`ll give this "UP" function a go next time we`re "up" a mountain :cool::giggle:
Folkranger
May 2, 2014
2,255
4,617
Washington
Hymer B 584DL
It seems to be the euro 6 lump that lacks the umph
Folkranger
May 2, 2014
2,255
4,617
Washington
Hymer B 584DL
We have had two Fiat 2.3 150 bhp powered vans and found they were plenty powerful enough we even towed a car trailer with the last one it never missed a beat😊
So have I. But it seems to apply to specific year/engines
11,963
16,582
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I have the same spec engine and year with comfortmatic.
Found it difficult on inclines or behind lorries trundling along at 57 mph.
Had it remapped by Quantum for £230 up to 180 hp once the 3 year warranty expired.
So much improvement-can breeze past lorries uphill at 65mph in 6th gear. Slightly better fuel consumption and a pleasure to drive
Nothing to do with Fiat but ....... I had my Merc V6 auto motorhome done by Quantum a year ago. It wasn't lacking in power or torque but I thought it could be better. I'm very happy with it. Idling is smoother and it holds rpm much better on motorway inclines. Using cruise control at 65mph it didn't change down pulling trailer & Smart car from the Lune Gorge to Burton Services heading North on the M6. Before tuning it changed down one gear under the same circumstances. (just an example of somewhere I noticed a marked difference).
tsrwright
21
9
Sydney
looking
6 years
Delighted with my 2016 model, remappd by Celtic in 2017 and going well at just over 20,000 miles
73
43
Worcestershire
Auto-Trail GF70
since 1993
Had my 2020 non ad blue 2.3L 130bhp re-mapped by ACE done a few months ago as it seemed pretty gutless. A major difference now in the 55-65 speed area without the changing down for slight hills!! I've had many with 2.3L 130/150 and 180bhp and never thought I needed a re-map. This one as mentioned did! I think some engines either have it or they don't, maybe how they were treated from day one but who knows??
Folkranger
May 2, 2014
2,255
4,617
Washington
Hymer B 584DL
Comes up too often so I think the common denominator is this engine, not how it's been treated. Also 16" wheels play a part.
236
495
Guardamar del Segura, Spain
Adria Sonic 700i SL
Had my 2019 Euro 6 Pre Adblue done yesterday, early signs are very positive, the guys at quantum tuning here in Spain dome a great job. Took it for a spin last night on some known roads where it would need a change down to 5th and all good, managing to stay in top gear. I can feel the difference very early on. We are going to take it inland over the weekend as some more challenging hills there so will update my post once we have done that , but as I say early signs are very good.
73
43
Worcestershire
Auto-Trail GF70
since 1993
Good news then - same as mine - it makes quite a difference!
5,602
10,473
Birmingham, UK
A-Class
Surely depends on tyre size rather than wheel diameter?
You'd think. But the tyre side wall ends up being nearly the same. From Fiats standard fit tyres, the biggest 16" has a rolling circumference nearly 10% bigger than common 15" fits... No wonder the speedo is so far out on some vans!
28
76
Dunoon, UK
Since 1994
And everything was designed to run on the standard 15inch wheels. The gear ratios, final drive ratio are changed by 10% on a 16inch wheel. My solution is to drive one gear lower much of the time and not use 5th much below 50 or 6th below 60. Yes the engine will pull those gears below those speeds but if you watch the instant mpg readout it works harder and drinks fuel as soon as there is even the slightest incline. I live in Scotland where there is very little flat road and after testing on the same journey several times have come to the conclusion that trying to use high gear with 16inch wheels uses more fuel.
5,602
10,473
Birmingham, UK
A-Class
I do agree that 16" wheels seem to make the gearing too high. And that it was probably optimised for delivery vans that run the cheapest spec, so 15".
I did a rough calculation. A motorhome has 25% more frontal area than a PVC. So not surprising that high speeds are more work.
7,361
11,927
West Sussex
Malibu Van 640 LE K
Since 2003
If you have a Comfortmatic the UP button helps to achieve similar results. It holds lower gears a bit longer and changes down a bit sooner.
Reactions: Joc
2,707
2,171
Northampton
Rapido & Bongone
so you would reccommend staying on 15" wheels
5,602
10,473
Birmingham, UK
A-Class
16" wheels look nicer. And I think they have a higher load rating if you're running a big van? Might be a better tyre choice too?
But they are heavier, accelerate slower, and the larger diameter isn't so good on the 6 speed box.
2,707
2,171
Northampton
Rapido & Bongone
the only reason i was concidering changing (steel) was for load rating and better choice of all seasons .
