Motor home engine turns over but won’t start,immobiliser light on.Fiat Ducati cab,15 years old (2 Viewers)
Jane Youd
5
Brersner
motorhome turning over but won’t start,immobiliser light on.15 year old Bursner with Fiat Ducati cab
2x2camper
851
2,006
That white clip hinges on the centre of the multiplug and pulls the plug and socket tightly together with a "camming" action. I would think a scrap yard would be your best bet but you may be able to jury rig something up with cable ties in the short term ?
Thata what I am aiming to do. However I need to get the motorhome home and it now won't start.
486
570
I met up with Vanbitz 'junior' at a show earlier this year and shared my pics and method as Ash still has a steady stream of people asking Vanbitz for help.
The simplest solution is to change the fuel pump for one withOUT the immobiliser chip. But a lot of people seem to want to try the surgical removal route. I didn't have much choice being on a relative's driveway blocking their access when my intermittent fault became permanent. 😁
Jev is the fuel pump on some Fiats not in the tank itself?
3,766
7,473
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
2.5tdi definitely a fuel pump between radiator and engine block and pretty sure the same on the next engine, the 2.8
Approximate location in pic.
6,827
12,599
Herts.
Adria Coral lowline
So even with the plug pushed and held in, the engine still won’t start. If that is the case it increases my dubious thoughts about the diagnosis.
2x2camper
851
2,006
Latest diagnosis is power is going into the ECU but not getting out. Currently on a flatbed being brought home.
Anyone know a good mobile mechanic in Milton Keynes?
97243
Our 2.8JTD started doing this a couple of weeks ago, but the problem is getting more frequent and more difficult to clear. I have re-read this thread, will try the various suggested remedies as and when it happens and report accordingly.
Fortunately, I have found a good independent mechanic very close to us in France who says that he is happy to tackle the Ducato mechanics, so I may well book the van in and let him poke around and see what he can find.
2x2camper
851
2,006
Sorted
Well I found a good electrician, me. That's after 3 so called professionals had a go at finding the problem, one I would let them plug a kettle in again.
So after all of the hassle trying to find someone to sort it I took the plunge and dif some basic testing, read the relevant wiring diagram and then pulled the wiring lloom part.
One pesty wire brought the van to a total halt
9,866
20,336
Newcastle under Lyme
Hymer B544 A Class
Was the blue wire chaffing on something ?
Good for you for sorting it when professionals couldn't 👍
2x2camper
851
2,006
So joining it fixed the fault ?
How did it get cut in the middle of the loom, looks like a clean cut
Correct. It powered a relay that was cutting off the immobiliser i think.
I can only guess that the wire was under stress in the loom and eventually snapped.
I ssume that the outer stetched and didn't break with the inner core as the break down guy got it going by effectively just moving the wires. He thought the problem was with the clip which held the socket into the ecu, which although was broken still held it in ok.
There were a couple of othe wires that when I was putting the loom back would have been under stress if you weren't careful. I assume it was that way when manufactured in 2007
507
1,305
Onchan, Isle of Man
Carthago
Since Nov 2010 after 25 yrs under canvas.
We had this earlier this year. In end it turned out to be my mobile phone too close to the ignition.
MrMorris
5
Fiat Ducato
eddie Are you still able to offer help with this issue. I can't see hiw to get your contact details and have a copy of my V5 waiting? Cheers
MrMorris
5
Fiat Ducato
Thanks, saw the offer before finishing the thread and am in a panic! Have 2 days to move the the vehicle and struggling to get help.
1,368
5,561
South West
Adria Twin
Since 1992
Any signs on mice having a nibble?
7,299
11,807
West Sussex
Malibu Van 640 LE K
Since 2003
Perhaps try AshVanBitz
If you by pass the immobiliser you might need to check the insurance implications. My insurance specifically says the theft cover is dependant on the immobiliser.
MrMorris
5
Fiat Ducato
I'm in Nottingham if anyone has any suggestions for who could help near me. Very grateful to hear from you
