Modified or pure? (3 Viewers)
Feb 26, 2013
1,653
9,415
Pinar de Campoverde, Spain
Giottiline T60
Since March 2013
I aim to buy a 1000w inverter and can see that pure sine wave inverters are much dearer than modified sine wave inverters so I am guessing the pure ones are better but can someone tell me what is the difference and is it best to pay the extra?
The main reason I need it is to power my low wattage travel hairdryer as it is clear from the forum that 12V hairdryers are only good for drying the back of stamps! :Smile:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
If you are only using a hair dryer than the modified will be fine.
Coolbeanz
Feb 26, 2013
1,653
9,415
Giottiline T60
Since March 2013
but if i have an inverter installed it seems logical it will be used for other things so do you know what kind of appliances need the pure as opposed to the modified? ::bigsmile:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
i have been using a 2kw modified inverter in my trailer for about 8 yrs . never found anything that didnt work on it . unless they were really big power suckers . it went wrong the other day .i bought a cheap one from ebay . again does every thing it says on the box . fridge ,computer,telly ariel drills washing machine . . i think modified is ok . others say not but i find it ok
43,331
49,480
modern electronics don't like modified sine wave of any source...Jennie or inverter.
Laptops, TV,s etc can't be damaged.
Now the tech bit in its most basic form:Doh:
Draw a straight line on a piece of paper.
Now draw a box on top of the line and another below the line but directly after the first....repeat along the line.
This is a square wave form...electrically speaking, the 'dirtiest' form of electric....heating elements will work fine but usually not motors etc
Next, draw what looks like a bicycle helmet then another below and upside down as in the square wave..
This is a modified wave form.......cleaner than a square wave but not clean enough for electronics....heating appliances and some motors Will work fine
Next draw a half circle in place of the box or helmet then as before.
This is a pure wave form and everything likes a pure wave....same as your house electric.
Incorrect waveforms can cause excessive heat to be generated in an appliance or motor.
haganap
12,762
26,460
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
I accept what John says.
However I have never had a problem, I have charged laptops iPads and everything else for 8 years +
I've used all sorts of inverters cheap and expensive. :Smile:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
I do have an inverter wired into the van. Its 2kw pure sine wave. I only use it for the microwave and hairdryer. Everything else is charged by 12 volt, laptops, tablet, phones and the TV are 12 volt.
43,331
49,480
but do you use the appliances while being charged Paul ?
Big difference between running a processor on an unclean power source and simply charging a battery on one.
haganap
12,762
26,460
planet earth
John I have always used them whilst on charge over many years. I have had the kids in the back playing on laptops and watching films whilst I drive. There is nothing we haven't used, even the Xbox and sky box at some point.
The inverter I'm using at present is a sterling 1800w modified sine wave inverter. If you read their explanation of pure v modified, they say it doesn't matter these days and give an explanation, of course they are selling the inverters, but we're happy :thumb:
43,331
49,480
Sterling is a well respected and recommended company who know their stuff so I would think their mod sine inverter will be a damned sight closer to pure wave than the cheap Chinese inverters.
You get what you pay for :thumb:
Jim
Ringleader
Jul 19, 2007
36,430
130,944
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I've used modified for years charging and using laptops and tablets. Always plugged into a surge protector though. They work fine:thumb:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
i can only agree with paul. i have a laptop with a knacked battery i have to keep charging it all the time i use it . in fact i have two like it .both havent shown any fault yet.
i understand what your saying ,but the only thing i have come across that doesnt like some inverters is a mates fridge . a small table top one . works a treat on a cheap chinese inverter bought in morocco for twenty quid . but plays up on some others . worked on my old ring inverter .
all mine work a treat . i just bought an under-counter fridge freezer for the truck .but only bought it after testing it .
i,m sure other things might be troublesome but havent really found it a prob. myself .
john you have seen mine from ebay .it works and it was a cheap chinese . mind so was the ring inverter.
43,331
49,480
never thought of that Jim :Doh:
Mod and square are susceptible to spikes, which is probably what causes the damage, and that will obviously iliminate them :thumb:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
i do use one of them bought for a few quid in asda . maybe thats the secret.
G8WVW
92
67
Cumbria
Since 1990 on/off
600W modified sine-wave has been brilliant for all the usual electronics only problem is I've burnt out two Braun electric toothbrush chargers in 3-months. Coincidence? Never has one fail at home in 15-years.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
i think these days you can get manual tooth brushes . that stops that happening . hee hee
yes i have heard of that problem . but my manual one is ok . :thumb:
43,331
49,480
I don't think coincidence....
Some chargers, including on-board chargers on mod sine generators, don't get on with modified wave
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
I learn more on here, than i do all day listening to the radio:thumb:
Bailey58
8,817
29,603
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
My 2000w Ring MSW doesn't do my Senseo coffee machine at 1450w. Might eventually boil but gives up when the dispense button is pressed. Ok on the kettle which is only 900w, perhaps the Senseo is too sensitive? :Smile:
Oh yes, having just returned from our France/Swiss trip I have to confess that the fuss about storing an extra gas bottle horizontally from 6 weeks or so back was unnecessary, we just about used the 6kg and never touched the 13kg let alone an extra one. :Doh:
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Thankfully I have never been asked to provide hairdryer power (yet) so we manage with just a 150W pure sine wave inverter to charge / run small appliances. I chose pure sine wave since the price premium was not too great for a small unit and wanted to ensure it would work on anything.
I believe things like toothbrushes that use inductance charging, and anything with an induction motor might not like a modified sine wave. Also, I have read several reports of modified wave inverters 'frying' GHD Hair Straighteners, which, I understand, are rather costly items and often cherished by the lady owners.
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
That's because MSW inverters are about 70 to 75% efficient.
Coolbeanz
Feb 26, 2013
1,653
9,415
Giottiline T60
Since March 2013
well this has given me lots of useful info which I really appreciate. As I love my electric toothbrush I will err on the side of caution and look for a not to expensive pure sine wave inverter. :thumb::thumb:
17,630
43,340
and look for a not [HI]to[/HI] expensive
Ooh grammatical error!! Not [HI]too[/HI] expensive. Phew :Doh:
tut tut the grammar police will be knocking on your door :ROFLMAO:
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
I believe things like toothbrushes that use inductance charging might not like a modified sine wave.
Exactly so. I have a 200w pure sine wave Sterling inverter that I use to charge my electric toothbrush - it just plugs straight into a 12v socket. Some shavers also use inductive charging so these would need pure sine too. I also use it to run my electric blanket (waiting for cries of 'wuss' :winky:) as its electronic controller would otherwise be damaged. The 1kw modified sine wave Silverline inverter is used to run my hairdryer. :Smile:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Strangely enough my factory fitted 2kv pure sine wave wont run my Sensio coffee machine but will run the microwave.
