ShiftZZ
Always had problems using them, I suspect it's the quality of the bit, any suggestions of a make?
Second that.. its the drill that's the important bit..It’s not always the bits that are the problem, the inner skin of my bungalow is solid and very hard brick, my normal Ryobi decent size hammer drill is no good but if I bring out the really heavy duty one which I bought from B & Q a few years ago it only takes a few seconds to drill a hole.
SDS every time, different experience, even the crappier bits last longer - except the Chinese ones of course.The problem is that I hit something hard and northing will shift it, then the hole gets bigger..
Agreed but you still need a holeSlightly off topic and I don't know the circumstances but chemical fixings with a threaded bar then fix with a washer and nut can be effective sometimes.
Agreed, agreed. I have used chem fixing and didn't need such a deep hole as anticipated and it fixes without exerting outward pressure. Not suitable in all situations though.Agreed but you still need a hole
Sounds like you have it the lintel. If it’s concrete a decent SDS bit and drill will do it. If it’s steel forget it.I'm tempted to 'stick' the piece of wood onto the wall and then add the curtain rail...
Got you now Dave....your drilling either a steel lintel (RSJ) or a re-enforced concrete lintel....most likely re-enforced concreteI'm tempted to 'stick' the piece of wood onto the wall and then add the curtain rail...
I have a similar issue. I suspect that the only way is a good heavy duty hammer drillThe problem is that I hit something hard and northing will shift it, then the hole gets bigger..
Never used anything but masonry bits with the hammer turned off.ceramic tiles you need the relevant drills.
and a bit of tape over the hole position to help stop the drill skittering.Never used anything but masonry bits with the hammer turned off.
Very light pressure and slow speed until through the glaze then you can speed up. Once through the tile put hammer on and drill as normal
Haven't cracked a tile yet
A lot depends on the quality of your Hammer drill!The problem is that I hit something hard and northing will shift it, then the hole gets bigger..
The inner course of most houses are made from common bricks, seconds, which are quite often from the outside of the kiln and over cooked, and contain bits that are like glass virtually impenetrable.
