Thinking of getting one but don't no anything about one.
have a avtex tv with the port.
like it for netflix etc.
You can try putting the usb lead into the tv to power it.....a lot of TVs supply enough power through their USB ports.I’ve just got one but you need a 240v source close to TV which is another job l have to sort.
I’ve never tested it......but I can tell you the max amps the psu is.....that I don’t use.What sort of power will it use with my tv?
Tv alone uses 3.33amp.
as I do a lot of wilding
Failing that put the usb plug into a 12v cigarette adapter.
My Avtex powers mine from its USB port and also works the same way in my kitchen tv at home.
I’ve also just changed to a 4K one in the van.....not for the resolution, it has a faster processor and a better WiFi antenna in it.
We have a small battery pack you can charge your phone with, as the van is new and I didn’t have time before our recent holiday to fit a socket I used this and it powered the FS no problem.You can try putting the usb lead into the tv to power it.....a lot of TVs supply enough power through their USB ports.
The USB port will have 5v at about 500mA which is the standard for usb 1 and 2, though some tv manufactures ignore the standard and skimp on the usb powerl thought of that but understood the USB to be an input port? It’s right next to the HDMI port that l would use for the FS.
Try connecting it to your tv’s usb.....it may work for you.We have a small battery pack you can charge your phone with, as the van is new and I didn’t have time before our recent holiday to fit a socket I used this and it powered the FS no problem.
Before you spend more money....try the usb lead in the tv, it may work.Now I have to find what a battery Pac looks like.
If you’ve got the extra tenner....I would.So the 4K one is the one to get.?
Mine flashed up message insufficient power but worked anyway and is still fine 6 month laterYou can try putting the usb lead into the tv to power it.....a lot of TVs supply enough power through their USB ports.
Mine in the kitchen has been saying that for 3 years....mainly when I update the fw.Mine flashed up message insufficient power but worked anyway and is still fine 6 month later
If your not in a great rush, Amazon have sales on their own devices about twice a year and it’s a good old saving.Ok thanks all job sorted.
Will look for prices.
Laurie
Yes, put "nice to have" items in a WishList at Amazon & look for sale pricesIf your not in a great rush, Amazon have sales on their own devices about twice a year and it’s a good old saving.
or look in the Amazon warehouse for a returned one or a Amazon certified refurbished one.
other than that the prices are just about fixed everywhere......
I thought about that but I’m sure someone on here had issues with their Avtex and this had caused it, plus the power pack is the size of a phone so no issues until I fit a socket.Try connecting it to your tv’s usb.....it may work for you.
I’ve never had any problems and have done this since the fire stick first came out....maybe I’m just lucky?I thought about that but I’m sure someone on here had issues with their Avtex and this had caused it, plus the power pack is the size of a phone so no issues until I fit a socket.
How did they determine that the fire stick was the cause of the damage to the tv....if it was that way round?
I’m not doubting what you have read.......I’m just curious as I’d hate to damage the ridiculously expensive Avtex pro in the van.I may be wrong I just have something in the back of my mind that someone posted it, I might be talking through a hole in my head again
