BBQ season. Gas, electric or charcoal? (2 Viewers)
Nov 8, 2022
47
23
Winchester, UK
Bailey 540
Newbie
Our 6m moho is fairly short of storage space so I'm looking for alternatives! Can't stand the taste from disposable bbqs, can't be bothered to keep cleaning out a " proper" charcoal bbq so a small electric or gas (canister - no extl bbq point in this moho!) Seems like a good idea. Pros, cons , experiences please!
Kannon Fodda
2,592
8,037
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
Unless you are always on Hook Up, or have a decent inverter with loads of battery capacity electric will be out. A gas thingy isn't really a BBQ ;) It's more of an outdoor grill.
I use a Cadac Safari Chef (there will be many detractors from Cadac, but it works for me), which can be floor standing or in my case I put on a table. It gets used most trips out. Plenty big enough cooking area for a couple. Two versions High Pressure and Low Pressure. HP the cannister screws directly into the underside valve. LP you have a hose and regulator into which the cannister can screw, but alternatively the hose could connect to the BBQ point you don't have. As standard a grill plate or flat plancha is used, and there is a lid useable as a paella pan. Also a stand so you could boil a pot or kettle. I also acquired a 50/50 grill/plancha which is ideal for the morning bacon and eggs breakfast. I find it works well, and is stored in a circular bag that will get into the under bench seat of my smaller than yours PVC. But, it is tempermental in windy weather so I often deploy a windbreak. After a couple of years it is getting more challenging to clean the grill plates, certainly not the easy wipe implied by some videos.
There are outdoor gas stoves that use cylindrical cartridges. Some have fittings for a grill, rather than as a stove. I suspect those are challenging to clean. Also limited with the size of the pot or pan so it doesn't overhang the cartridge area. But advantage is these can be very cheap and quite compact. I used a couple regularly when I had a tent, before upgrading to the Cadac.
Feb 22, 2011
9,839
20,287
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Good advice.
I use a cadac safari chef and find it ok but does take some cleaning afterwards. I also use disposable bbq's too if I can't be bothered with cleaning. Never found an unpleasant taste with one.
But for true bbq flavour you really need a proper charcoal bbq of which there are many, but all will have some mess to clean up.
Wessexwanderer
Nov 8, 2022
47
23
Winchester, UK
Bailey 540
Newbie
Good advice.
Two votes for Cadac then!
Sep 15, 2022
8
11
Greater Manchester
Pilote Atlantis A5
Newbie
We recently bought one of these:
Broken Link Removed
Not used in anger yet - although that will be rectified over Easter. I was pretty impressed with it as I unboxed and it came in a bit cheaper than the Cadac.
As it is a gas grill, I am going to try liquid smoke (bought from Amazon) to try and replicate the bbq taste. I'll post again once we've cooked on it !
Apr 22, 2018
6,827
12,598
Herts.
Adria Coral lowline
Webber go anywhere gas is a good, light, small bbq. Obviously don’t clean it too much and keep it bagged whilst in transit. The Webber Q is better but much bigger, heavier, costly, and not vet mono friendly.
I much prefer coal, but these days too many sites say no. They are not so popular on aires, and need more bits lugging about for them.
Id never touch another cadac product ever, after buying a cadac grillogas which was the biggest piece of sh..
Feb 18, 2017
4,134
8,017
Greenwich, London, UK
Hymer MLT 570
Another vote for the Cadac range.
We have the Safari 2
Superb bit of kit. (But is an outdoor grill, not a true BBQ)
We never fry anything inside our van. Not even an egg. (Smell, danger of fire and sticky residue)
We always use the Cadac outside for all frying and BBQ'ing .
What you could also get is the Snow Peak fire pit
They are expensive, but well worth it, both my brother and sister have one.
(Make sure you get the large one, the small one is just for picnic use)
They can be used as a log fire pit (without burning the grass), as a charcoal or coal BBQ if you add the grill on top, and as a place to boil a kettle or even roast meat on a spit.
They fold completely flat. and take seconds to erect.
Best of all as they are an inverted pyramid the fire keeps concentrated as it burns lower, so that you have very little ash and it will keep giving out heat to the very end.
Jun 17, 2015
270
470
Portsmouth
Pilote G740
July 2015 plus 20 years of camping
I've been using my Webber Baby Q for years now and its great. But I still love the charcoal flavour from a decent real BBQ. Maybe when I get my new van I'll have another go finding a chacoal BBQ that is easily portable and motorhome friendly (small, easy to clean etc)
Apr 17, 2016
5,990
35,575
South Coast
White One..
3 years….
Have a Weber Q1000 on board all the time, brilliant BBQ, have made up an adapter to run it off the van gas tank.
And it fits snuggly in my gas locker😁
Apr 19, 2019
2,292
4,851
Carado T339
5 years
You are not supposed to each the charcoal.
I always thought it was a myth that food tasted different from charcoal bbqs. You are not supposed to put food on them until all the smoke has burned off. A proper gas bbq is not a grill as the fat drops onto the flames, thus creating smoke which adds to the flavour. A grill is from the top down.
My vote is for the weber mini bbqs. Proper cast iron.
Wessexwanderer
Nov 8, 2022
47
23
Winchester, UK
Bailey 540
Newbie
Falcon 269
381
1,335
Melton Mowbray, UK
Another Cadac user of many years here. Although I agree that charcoal BBQs can produce better flavour if used properly, gas wins hands-down for convenience.
To make cleaning the Cadac grill and griddle plates easier, I use circles of the silicon sheet material widely available for ovens and grills.
Jun 30, 2022
346
2,112
burstner lyseo 590
We love the cadac too (only had it since last year)…and also use the non stick oven liner stuff…Makes cleaning a doddle!
Sep 3, 2009
1,532
6,284
NW Surrey
LHD Hymer exsis-i
Our RV had a built in gas BBQ with lava rocks , which I always thought enhanced the flavor. When I get around to having a BBQ point fitted in current van, I’m getting a small portable one from Amazon for under £40
Mar 23, 2012
9,577
32,224
sleights
c class
We bought a safari chef and got rid pretty quick it was a pain to clean. We now used a £10 cooker that takes a gas cylinder and a square ilea non stick pan . Light easy to set up easy to clean. We also have a charcoal BBQ with a fan built in quick and easy to light reasonably easy to clean. Be aware that in France there are a lot of restrictions on charcoal BBQ for safety reasons.
Feb 16, 2020
2,311
3,157
KT15.
Sunlight. T66. 2019.
Absolute beginners.
No, all to much hassle. The people at the back of us on the other hand love a smoky BBQ as I can attest to frequently having to run out and grab the washing in before we have, oaky smoky sheets all fecking week on the bed. :rolleyes:
Mike.
Sep 10, 2012
2,136
3,758
worcester
Sunliving van
Small van small solution. Get a small table top gas ring with disposable cartridges and a griddle pan. Our pan is an oversized oblong shape so one end is for cooking(frying) and the other end to keep cooked warm.
Never going to match charcoal for taste or smell but u can cook outside if that's your thing.
TOAD on Tour
768
1,231
Lincolnshire
VW Grand California
Since 2020
We use Cadac and also Weber Smoky Joe for a charcoal option. More importantly buy good Lumpwood charcoal (restaurant grade) and natural firelighters. I also have a Kamado Joe Junior, but don’t always take that as it’s 40kg! I like my bbq’s.…..have Kamado Joe’s bigger brother and a Weber 6 burner gas bbq at home 🤪
MisterB
5,930
13,267
Essex
Adria 670 SLT
We have several cadacs and this option really is a game changer. Used with LP cadac, it gives the freedom of a HP cadac.
We love pizzas on the cadac (using a pizza stone in top of the griddle plate)
Aug 8, 2019
390
554
Chichester
Autosleeper Broadway
Since 2019
That's exactly what we use. We tried a small cadac but it was a nightmare to clean
