- Apr 27, 2008
- 12,079
- 14,722
- Hymer low profile
- Since 1972
Yes the A Class space increase is very small, just a few inches in width at the front, however the perceived space is much greater.
To be fair it depends which "A class" vans you are talking about, Jon's N+B Clou is on a MAN truck and maximises the available chassis space by building the habitation over the engine with the dashboard as close to the windscreen as is practical, this is quite easy with the extra height of a truck chassis but not quite so easy on some other "A class" that are built on van derived chassis, for example Concorde N+B Flair and indeed our MORELO all have a modified layout where the whole dashboard pedals and steering are all lifted and pushed further forward so yes there is a "real" gain in space and build costs some other "A class" vans have a lot of space between the dashboard and the windscreen and even from the front seats to the edge of the van, end of the day there are reasons why some vans are a lot more money than others.Is that ”real” space or perceived space?
They look/feel roomy when inside but if it’s the same size and layout. Isn’t the dash and seats in the same space, you just get massive dashtop, and a lot more glass???
Sorry but that ridiculous. You can’t even stand up in that, let alone live in it.This is ma pal Louise van ...she buily it herself, mobile pet groomer with 3 dogs of her own and lives in this. And shes well happy View attachment 638978View attachment 638979
Ahhh. Ok that makes sense. I’m in the lower budget brigade, and I’ve only seen van conversions, so the dash has always been standard, so no real physical space, just a roomy feel. Which is nicer than just a van but not massively so.To be fair it depends which "A class" vans you are talking about, Jon's N+B Clou is on a MAN truck and maximises the available chassis space by building the habitation over the engine with the dashboard as close to the windscreen as is practical, this is quite easy with the extra height of a truck chassis but not quite so easy on some other "A class" that are built on van derived chassis, for example Concorde N+B Flair and indeed our MORELO all have a modified layout where the whole dashboard pedals and steering are all lifted and pushed further forward so yes there is a "real" gain in space and build costs some other "A class" vans have a lot of space between the dashboard and the windscreen and even from the front seats to the edge of the van, end of the day there are reasons why some vans are a lot more money than others.
You can't!Sorry but that ridiculous. You can’t even stand up in that, let alone live in it.
I have to laugh when I see some of those huge vans taking the toilet cassette out,,,some are that small they would not last us a night..BUSBYMine is a 7m however am away to look at 8 - 8.5m vans when I get home been parked up beside to many Morelos
Was taking the pi.. but it does seem to be that the bigger the van the smaller the cassette..BUSBYI wouldn't like to have your guts/bladder if you can fill up a cassette in one night.
I thought most "big vans" had black tanks so no worries in that department or maybe our definition of "big van" differs.Was taking the pi.. but it does seem to be that the bigger the van the smaller the cassette..BUSBY
Its definitely real space. My 7 metre hymer had much more space than my 7.3 metre iveco daily.Is that ”real” space or perceived space?
I still think that if you were to compare a ducato based A class to a PVC you would find it significantly roomier because the more square shape and extra width of it allows everything to be pushed outwards so its possibleto fit more into the same length, tranverse beds being a big difference. You can also add improved insulation etc because you don't have the problem with the doors and the generally iregular shapes. Of course each version has its place and for example many people feel unable to adapt to the same size A class because ironically they feel bigger than they actually are.Ahhh. Ok that makes sense. I’m in the lower budget brigade, and I’ve only seen van conversions, so the dash has always been standard, so no real physical space, just a roomy feel. Which is nicer than just a van but not massively so.
Actually Geoff my Clou on a MAN chassis is 1 metre longer but the wheelbase is only 100mm longer than my previous 7.4m ArtoInterestingly nobody on this thread has so far differentiated between the driving characteristics of van-based- and truck-based chassis MHs.
Truck chassis have a wider track, but apart from putting the wheels in line with the bodywork, instead of inset, does not make much difference.
Truck chassis have a longer wheelbase, so for the same overall length have less overhang.
Truck chassis also tend to be higher.
The last two factors make grounding a lesser problem for vehicles of the same length.
As trucks tend to be rear-wheel drive the steering angle can be sharper which affects the turning radius, but watch the rear swing.
I would prefer to drive the truck-based MH, but then I drove trucks that size before.
Definitely. Even the width in the vario i was building is a lot less than the euramobil a class i now have. Its only 700mm longer but the width makes a big difference.I still think that if you were to compare a ducato based A class to a PVC you would find it significantly roomier because the more square shape and extra width of it allows everything to be pushed outwards so its possibleto fit more into the same length, tranverse beds being a big difference. You can also add improved insulation etc because you don't have the problem with the doors and the generally iregular shapes. Of course each version has its place and for example many people feel unable to adapt to the same size A class because ironically they feel bigger than they actually are.
I've seen some really nice ex library motors around. There used to be a guy on here libraryman stan?? Some of them are really decent motors.Definitely. Even the width in the vario i was building is a lot less than the euramobil a class i now have. Its only 700mm longer but the width makes a big difference.
If i decide to do a self build now im planning to do it on either a vario pick up with a box body or a 7.5 tonne cargo or merc 814 truck so i get the width
Not actually true. Try taking large motorhomes onto some of the National Park campsites, for example Olympic National Park where the majority of RV pitches will accept no more than 21 ft motorhomes.If you live and travel in the USA I suppose nothing is too big
Gina
We went from 6 m PVC to 6.4m A Class. We changed as I am 6'3" and I wanted more space, mostly a bigger space to relax when the weather was poor, as it was in our Spring break in the Algarve, Spain and France. I can now stand up with some spare headroom throughout the van, we no longer have a shower curtain, the transverse bed is no longer 'just about big enough' ( and we have another one above the cab), the view out the front is much improved, our bikes are now in the garage instead of on a rack (which made the van over 6m anyway ), the lounge area is bigger and feels much bigger than it actually is, the floor is all one level, we can pass each other in the galley, the van is warmer and has better storage due to the double floor. My only gripes are... the van is 10cm wider, the cab door is on SWMBO's side and we are much more conspicuous, being a white motorhome instead of a grey van. Oh, and we are skint!!! ( broke, as our southern UK neighbours would say).I still think that if you were to compare a ducato based A class to a PVC you would find it significantly roomier because the more square shape and extra width of it allows everything to be pushed outwards so its possibleto fit more into the same length, tranverse beds being a big difference. You can also add improved insulation etc because you don't have the problem with the doors and the generally iregular shapes. Of course each version has its place and for example many people feel unable to adapt to the same size A class because ironically they feel better than they actually are.
The glass makes a huge difference. The extra width in the cab does offer more room and storage on one or both sides. The 1/2 acre dash top swallows all sorts when parked up.Is that ”real” space or perceived space?
I’m talking about a coachbuilt to an A class.I still think that if you were to compare a ducato based A class to a PVC you would find it significantly roomier because the more square shape and extra width of it allows everything to be pushed outwards so its possibleto fit more into the same length, tranverse beds being a big difference. You can also add improved insulation etc because you don't have the problem with the doors and the generally iregular shapes. Of course each version has its place and for example many people feel unable to adapt to the same size A class because ironically they feel bigger than they actually are.
Dennis isn’t allowed to drink beer……BTW, if Dennis (the poor sod) lived local to me, I'd be taking him for a pint, and a much needed blokey type of break from Karen. I bet she has a pair of boots, very much like Nancy Sinatra's.
Must be interesting in a landy thenI’m talking about a coachbuilt to an A class.
I can’t do transverse beds as I’m 6.4 and a constant pisser. Longitudinal singles only
That was needlessly personal.‘the stress of it all is making his Rohan shirt and trousers ‘Moist’
Oh yes I am !!Dennis isn’t allowed to drink beer……
