Which WiFi system to install
County Durham, UK
Hymer Free 600
Only a year
I hope to fit a WiFi or it is MiFi system in the van.
So advice please, do I go for a complete system from Falcon or Avtex or a mix of components such as roof antenna and router?
Also which system if a complete one is best for reception (I know a lot of this would also depend on SIM card providers). As there seems to be a great variation in price from various models of same maker.
Last bit, biggest data use would most likely be TV streaming (I think)
Greenwich, London, UK
Hymer MLT 570
Do what I did and contact the experts
Motorhome Wifi
After discussion we worked out what I needed, and which provider etc, and then they arranged for it to be fitted.
A pair of mobile technicians arrived in a van from Birmingham (van was in Kent) and fitted and tested the entire system in about 1 hour!
(They were doing 4 more that day in the same area)
North Norfolk, UK
Bailey Approach 745
I have the Avtex system. Combined with an EE sim it provides great Wi-Fi in most places we visit, which tend to be rural and off grid.
Our use is largely tv streaming, Netflix and prime
What would I do next time?
Buy a Poynting antenna and a router and ‘home brew’ it.
Spend as much as you can on the antenna.
Piece of cake to fit.
Tony
Uk
I bought this MIFI from eBay, listed as ‘grade C with heavy marks’ but it is perfect condition, not a mark on it. I’m very pleased with the whole setup
And I already had this antenna
I’ve also had a holder made by PaulandChrissy
Gellyneck
More than toes wet now!
Apart from the holder we've got the same as Manic. (y)
Hymer B544
2001 Caravans 2011 Motorhomes
“A complete system” from one of those companies is just a mix of antenna and router, so why not choose your own mix.
I started off with a second hand Cat 4 Teltonika RUT950 bought off eBay for £85. It had x2 LTE x2 WiFi connections so I looked for the best aerial to match and after a lot of research about performance I chose a Panorama (5G Great White), though the Poynting was also on my list.
I’ve since upgraded to a Teltonika RUTX11 router that is Cat 6. I chose that because it also has x2 LTE x2 WiFi. I won’t be changing now as 4G Cat 6 is more than adequate for streaming TV, using laptops, pads etc.
The antenna has proved brilliant, getting a clear signal in areas where our phones were completely useless.
There’s loads of threads on here about the subject and companies like Avtex ect simply put something together and charge you a premium for doing so.
We also use EE.
OttovanKamper
County Durham, UK
Hymer Free 600
Only a year
We also use EE.
I have just used your antenna choice and done a search. It has a lot of choices for connections and cables so not sure exactly what I should choose.
I agree it would be a better option than getting a system from Avtex. Just need to sort out the configuration now.
Hymer B544
If you look closely at the Avtex system it comprises of a x2 LTE lead Panorama, cheaper end antenna, together with what is clearly a Teltonika router, probably something like the RUT955 Cat4 or similar.
It’s the Avtex system that I based my system on, I just upgraded the antenna and router choice.
Have a look at Poynting and Panorama for antennas, you just need to decide on what router you want and match the number and type of leads accordingly.
If I was starting again I’d choose the RUTX50 (5G) and either a Poynting or Panorama antenna that had the x4 LTE x2 WiFi leads.
Though as I said previously Cat6/4g is more than enough for motorhome use, so I won’t be changing now.
WESTY66
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
I have the system from Motorhome WiFi with an EE sim and it just works flawlessly all over Europe, with 50gb in eu per month!
Never let me down👍👍👌🏼
Cheshire, UK
AS Warwick XL MQ
Since 1986
+1 for Avtex (AMR985)
Have used it from Italy to Norway and all places in between. Has worked really well with no problems. You can interrogate it through the IP address to find the best network available when abroad.
