- May 16, 2021
- 1,318
- 1,858
- Autotrail
Well .... you are I would say.I'm thinking that the best solution is to go with Phoenix Inverter Smart and separate Blue Smart IP22 charger connected to a transfer switch such as NDS Priority switch. This way it gives complete control of both devices which can be turned off when not required. Only advantage I can see of Multiplus II over this configuration is the Power Assist function. Or am I missing something.
Apart from Power Assist, which is VERY useful, you don't have a way to set a current limit, which is useful even without Power Assist (not all MPs have Power Assist in fact, but they all have setable current limit).
Another benefit is cost. The Multiplus is not a cheap product by any means, but when you compare the cost of a Multiplus against the cost of a Victron Inverter of the same output AND the cost of an AC Charger of the same output (the biggest IP22 charger will not come close to any Multiplus except the very smallest ones), it becomes the economic choice.
Then you add the other advantages and ... well, say no more.
Put it this way .... I fitted the Multiplus 12/3000/120 in my last camper conversion. When I decided to get a 'pre-built' Motorhome, one of the first decisions I made was not whether to get another Multiplus, but just WHICH ONE to get
