Which grey/waste tank cleaner - votes please (1 Viewer)
Jun 12, 2017
1,476
3,730
Telford
A class Pilote
The branded thetford stuff is the only stuff that stops any rancid smell.
We've tried every option, coke, washing power, but the smell can still be awful when empting.
Its not a huge expense, a small amount capful every few tanks, and no smell when emptying. We use less than the recommended dose.
(We have traps so never have internal smells, but I don't like leaving a stink bomb at disposal points - though seems I'm in the minority on this! Mines electric dump too so I don't even need to be near it, but still.....)
+1 for this. Tried the rest and now using the best
Apr 9, 2018
8,982
47,326
Worcestershire
Bailey Adamo 75-4t
March 2018
I see above people using citric acid in their boilers. I assume there is no detrimental effect to the innards?
If using the powder what ratio of powder to water please?
Riverbankannie
10,893
63,504
Bristol
IH 630 RL PVC
I use this formula
Descaling Dilute 1 or 2 tablespoons of citric acid in 1L of cold water and use this solution to descale coffee machines, kettles, cups, taps, showerheads and more Rinse with clear water afterwards. Toilet bowl cleaner Pour half the bag into your toilet and leave overnight.
Oct 13, 2019
9
5
Son en Breugel, Netherlands
Carthago C Line
Since June 2020, newbies
Thanks for this advice. These chemicals are so expensive and it’s good to hear a solid recommendation.
I agree - we use it now for all our trips, and we have had a couple of longer trips, 60+ days, works well. We do take a couple of bottles with us to last 😊- not always easy to buy in some countries.
28
19
Bristol, UK
Frankia
White vinegar. Cheaper than chips (certainly in France) and no smell or sugar. Pop a litre down the drains now and again. Drive around, then dump (in a designated drain of course). At the end of each big trip, a couple of litres in the main tank and run through the boiler and pump and aftwards run a half tank of clean water. No smells, no calcification.
I just bought some: 39p for 500ml in Lidl 🙂👍
Oct 3, 2022
40
52
Hymer B564
We used to use a couple of the largest bottles of dilute orange juice just add a bit of water to it, a good slosh around and leave for a couple of days and flush out. Another one we use regularly now is 3 or 4 steradent tablets into the full fresh water tank drive it all thru into the grey tank leave a few hours flush it all thru.
Feb 22, 2024
17
70
Just looking
This is what I use. It works brilliantly, killing two birds with one stone! Great washing up liquid, with a lovely smell, plus it cleans the pipes and keeps the waste tank smelling fresh.
I already use a Qualkem product for cleaning and soaking my brass instrument, so I know it's a good make, and their products work
Jul 24, 2018
58
34
South Yorkshire
Benimar coachbuilt
Since 2018
Just wondering how much water is in the fresh water tank when you add the two litres of vinegar to clean after each big trip…?
Nov 19, 2021
922
2,077
Nr Wigan, UK
Rapido A Class
Did a waste tank clean while in France the other day. Emptied the tank then put 3 x bottles of cheap coke down the sink.
Drove for a couple of hours onto next aire then dropped the coke. More than happy with the result, no smells 👍👍👍👍👍
Note to my self to do this more often 👌
Jul 28, 2008
844
779
Wiltshire, UK
Ducato Sportivo
Since 2005! 2000+ nights so far...
Which is more expensive than dose of the branded stuff? :)
We also tried coke, but never really worked - so not sure what we were doing wrong
