Why hasn’t this voltage issue on Lithium batteries been mentioned before ? Is it actually an issue ?
Some devices will not work with an unregulated supply, these are normally ones that are designed to work from a 240/12v transformer, they will either not work if they have overvoltage protection or will fry if they do not have overvoltage protection, think of it like a 12/24v laptop supply, it takes the vehicle voltage and transforms it into the voltage required by the laptop, a regulated 12v supply works in a similar way.Adding a regulator is a waste of energy (yours and electrical) in my opinion
If it's designed to work in an automotive environment, it should be fine with the higher charged voltage of lithium. An alternator can kick out more than 14v.Some devices will not work with an unregulated supply, these are normally ones that are designed to work from a 240/12v transformer, they will either not work if they have overvoltage protection or will fry if they do not have overvoltage protection, think of it like a 12/24v laptop supply, it takes the vehicle voltage and transforms it into the voltage required by the laptop, a regulated 12v supply works in a similar way.
Because it has nothing to do with lithium batteries. As already mentioned AGM batteries involve higher charging voltages than lithium.Why hasn’t this voltage issue on Lithium batteries been mentioned before ?
Not as far as I am concerned. I had lithium in my previous 2 motorhomes and had no voltage related failures in either of them.Is it actually an issue ?
Yes, I agree, but it is possible to use domestic 12v devices in a motorhome but you may need a regulated supply if you do. I speak from first hand experience.If it's designed to work in an automotive environment, it should be fine with the higher changed voltage of lithium. An alternator can kick out more than 14v.
Really? There are very, very few devices that use a transformer these days. Most will be power supply units based around electronics. Transformers are heavy.Some devices will not work with an unregulated supply, these are normally ones that are designed to work from a 240/12v transformer,
Maxxfans were known to toast their control circuits if run on too high a voltage, whether from Li, Solar or B2B. (May have been sorted on latest deliveries...?) Humble Road has a whole youtube on the subject...Adding a regulator is a waste of energy (yours and electrical) in my opinion
Agreed. I used 12v domestic LEDs in my previous van to replace incandescent bulbs. The one in the loo kept dieing... Took me a while to realise that I was using it in the day (no window, it was dark) so it was seeing much more than 12v when the solar was running. Meanwhile, the LEDs in the kitchen were fine because they generally only got used when it was dark.Yes, I agree, but it is possible to use domestic 12v devices in a motorhome but you may need a regulated supply if you do. I speak from first hand experience.
Apologies if my terminology is inaccurate, I wasn't referring to the big old transformers of yesteryear, I was referring to the modern equivalent, a device that transforms domestic AC mains supply into a lower voltage DC supply.Really? There are very, very few devices that use a transformer these days. Most will be power supply units based around electronics. Transformers are heavy.
Many Telys are 12v feed by a box it is feasible to feed them 12v direct but they may need regulating or at least not powered by a running engine. A simple inline 7812 regulator could do the job (google for circuit) for specific devices.Some devices will not work with an unregulated supply, these are normally ones that are designed to work from a 240/12v transformer, they will either not work if they have overvoltage protection or will fry if they do not have overvoltage protection.
How not to do it?Don't expect i've missed anything important.
Apparently if he or others promote a product for 2-3mins in their video they can keep it. Many do that and then sell, very nice it it’s a £1k bike. If the complete video is about the product they can be paid a very tidy amount sometimes more that all YT earnings for a month. Wonder what the taxman does about this ?
Many TVs are designed to run on an external mains to 12v supply that would give them a much cleaner feed then you'd get from an automotive socket. So unless it's designed to take the large range you'd expect in a van (regardless of the battery type), then yeah, you should probably fit a regulator.Many Telys are 12v feed by a box it is feasible to feed them 12v direct but they may need regulating or at least not powered by a running engine. A simple inline 7812 regulator could do the job (google for circuit) for specific devices.
PS ive not watched the video. Don't expect i've missed anything important.
You and I know what a 'transformer' is technically, but the modern usage of 'transformer' on the internet is anything that converts one voltage to another, DC or AC, especially if it is a brick in the middle of a wire. They almost all use switch mode technology, not the old transformer-rectifier-smoother technology.Really? There are very, very few devices that use a transformer these days. Most will be power supply units based around electronics. Transformers are heavy.
The dictionary definition of a transformer isI agree but the misuse of the term doesn't mean it shouldn't be corrected if likely to cause confusion. Wallwart, PSU, and power supply are also terms used but less like likely to confuse. Someone searching for a 230v to 12v "transformer" is likely to find something like https://www.improducts.co.uk/product/transformer-230-12v-150va/. Potentially worrying if they don't understand it would need rectifying and smoothing first, and also open mains connections.
“a device that changes the voltage or other characteristic of electrical energy as it moves from one circuit to another”.
Technical definitions may vary from this but I think you will have to forgive the non-technical general public for using the term transformer as it is defined by dictionaries without regarding it as misuse.
I recently installed one of those to power the Maxxfan, because it used to be sensible to higher voltage. I believe this is not the case anymore, but better safe than sorry with that expensive thing.
