- Apr 11, 2015
- 6,075
- 64,461
- Laika Ecovip 300
- since 1988 with breaks until 2009
Tried lights on and off key in the ignition and turned on no idea what number it went to but showed we were in Neutral i think. your right about the side lights switch light switch has two positions only off or on. bu**er when you go somewhere where it is illegal to run on sidelights. This is third time of being in van and fisrst tme this has been illuminated, am sure it's because i was fiddling with the stalk on the way home before lockdown.Did you have the ignition key in, on position 2, with the headlight switch on, which allows for sidelights only while parked up. Certainly on a 2015 van, you cannot just use the sidelights while driving, and have to have the key in, and turn on the headlights, without the engine running. It may be a second indication of the sidelights being on, as well as the illuminated green sidelight indicator.
will give you a wave in passing it's only a couple of minutes, if that, of a detour.Sue you are driving some funsters crazy ... get your bum in gear and check it out before they sue you for causing them stress!
