And I've yet to find a small modern combustion- engined car that can match my old Velocette Venom's 100+ mpg
If the neighbours are so lovely, why do you keep running over them?Have just changed a wheel.. again.
Began during Easter week, when I got a rear flat and it put the kybosh on going away for Easter Sunday as the spare turned out to have a broken valve.
Walked the spare to the tyre shop and they repaired it, walked it back and swapped the wheel over and a week later, the other side went down. So, walked the original puncture to the tyre shop again and they repaired it, brought it back and swapped it over - I had at that point four functioning tyres, so then drove to tyre shop and they repaired the second puncture.
Two weeks on (last week) moved the van - the neighbours moan - to the same spot where the second puncture appeared... and got a third puncture. On the front this time. Today, I swapped it for the spare - which was one of the original rear tyres. I had intended to take the van out but in the end I didn't move it.
I'll take it tomorrow tho to the tyre shop to get the latest puncture repaired. I'll be asking them to tell me what kind of puncture it was because I think there is a possibility it may have been one of my lovely neighbours...
Thank goodness puncture repairs don't cost much!
Can I ask you if you have any of the bottom plastic section which you will not require?Dometic fly screen seriously broken following temporary repairs earlier this year. Looks like the only solution is a £375 replacement for a problem caused by a bit of string costing about 10p! Dealer & Dometic not interested.
I think that might have been the bit that snapped off on mine, I glued it but it just snapped off again. I’ve retained this bit if it’s any use?Can I ask you if you have any of the bottom plastic section which you will not require?
this View attachment 764765broke off mine so the vertical plastic handle(sic) is very difficult to keep on the running strip at the
My awning!Hopefully have sorted a sticky HAB door lock that often did not lock or unlock when using the key fob. I was going to use just the normal WD40 but read this is not the correct lubricant to use. Instead purchased some WD40 dry PTFE and it seems to of done the job but early days yet.
Depending on the rear brake set up of course, if it’s an Alko Chassis and internal brake shoes inside the top hat disc, then an easy tip to get the hand brake adjusted, is to simply remove one rear wheel bolt, insert a long flat head screwdriver and adjust that way. With the handbrake off, the rear jacked up and safely chocked and on axle stands, turn the locking wheel located inside the drum (as per illustration below) until the wheel is solid and won’t turn at all and then slowly back the adjustment off until the wheel freely rotates. Pull the handbrake on and off a few times and check the wheel both locks when the handbrake is applied and free to rotate when released. Then do the other side and don’t forget to replace the wheel bold and torque it up again. Recheck after a few miles.Had the handbrake adjusted as it scraped through the mot, 1 wheel of 4 passed and a marginal overall pass .
Will take it out for a run and test over the weekend if I get a chance.
Yes absolutely, but if like me, you’ve completed that task, but want to check and adjust before mot etc, tis an easy tip, that’s all and it gives a choice if required.If you have done the work to get the wheel off, you would be better off to remove drum, check clean, and abrade the drum and shoes before adjusting them.
Last year our front discs needed replacing so I got the garage to do it. They charged us £180 per disc, not including the pads or labour!My job consisted of booking the MH in to my local garage to have all 4 discs an brake pads replaced as part of the annual service and MOT.
My next job is to find the money to pay for it!
The MH is 12 years old, (and 40k miles), so can't really complain.
Good on youLast year our front discs needed replacing so I got the garage to do it. They charged us £180 per disc, not including the pads or labour!
This year I replaced the rear discs and pads myself. Total cost £103.
For maximum efficiency, it is prudent to release the handbrake /undo cables , that way you know that even when the handbrake is off you know there is no tension pulling on the mechanism/ brake / brake pads before adjusting the footbrake side, the when they are adjusted refit/ tension the handbrake cables.Yes absolutely, but if like me, you’ve completed that task, but want to check and adjust before mot etc, tis an easy tip, that’s all and it gives a choice if required.
Also, the illustrations above, show that task as well. Aren’t I a good Bear
