- Apr 14, 2023
- 410
- 681
- Bailey
If you have 50mm already on a single Fogstar Drift 300Ah, then that is fine, you wouldn't need 2. The cable lengths only need to be identical if you are adding another battery so both charge and discharge at the same rate.Hmm... I'd seen that and somehow forgotten it along the way. I know it's overkill, but I could use 2 x 50mm (which I've already got) rather than buying 70mm...
I'm guessing you keep the cable lengths the same, use the same lugs etc so that they're as 'equal' as possible.
Edit: I should caveat this by saying I'm referring to hi-flex battery cable, of which the 50mm version is rated at 345A.
