My thought also. A toad was one of our considerations when choosing a PVC/MH, for us the PVC negated it even though we have a toadable little car. They will have their reasons of course.don't often see a PVC with a toad..
Can you explain the train weight please, and how I find it for my motorhome?Before looking for a car check your train weight.
That's the weight of both van and car combined.
If it's withing the train weight then ok.
If it's more it's not legal.
The VIN plate has this information .. usually in the engine bayCan you explain the train weight please, and how I find it for my motorhome?
Thanks.
I may use a trailerIf I did want to take a tow car I'd use my VX220. (It would need to be trailered though)
Thank youThe VIN plate has this information .. usually in the engine bay
example plate
The first weight is the MAM .. 3300kg .. (Max Authorised Mass)
The second is the Train weight 5300 kg
subtract the MAM from the Train gives the max towing weight
in this example that is 2000kg
the other two weights are front and rear axle weights
if you plan to go abroad that is a good plan.. A frames being illegal in most EU countries..I may use a trailer
Thank you
I may use a trailer
Thank you
Came as a pair.don't often see a PVC with a toad..
Came as a pair when we bought from Old Mo.My thought also. A toad was one of our considerations when choosing a PVC/MH, for us the PVC negated it even though we have a toadable little car. They will have their reasons of course.
We used to tow our Eunos Roadster (MX5 import) as there wasn’t anything to hang the frame off..If I did want to take a tow car I'd use my VX220. (It would need to be trailered though)
I was told by two companies that there is nothing at the front that would be suitable to hang an A frame onto so we went for a trailer. Having had a rummage around under the bonnet I can understand what they were talking about. The first substantial is the crossmember way back from the front. Everything from the nosecone are just panels and plastic.Tell me more about your MX5 Please! We have an MX5 mk2.5 Phoenix, I’d read that you can’t tow them as it buggers up the gearbox and differential. Did you have any issues? We currently tow Kathryn’s Aygo but when the Samoyeds pass away we’ll only have Rosie the Yorkshire Terrorist with us and she loves the ‘5. (The Samoyeds and the Terrorist can’t all fit in the ‘5 if I take SHWMBO as well)
Cheers!
Russ
