Water level indicator fault (1 Viewer)
OldWomble
141
123
West Sussex
AS Kemerton XL
25 years
Morning all and Happy New Year
Both the level indicators on our Auto-Sleepers PVC are showing inaccurate readings. The fresh tank shows 1/4 full when it’s completely empty and the waste tank also shows 1/4 when that is full to the brim.
So far, I have drained and cleaned both tanks with tank cleaners and citric acid, flushed them several times and then checked everything again. No change!
I then removed the sensors from the fresh tank, cleaned them and refitted them. No change!
I have now disconnected the wiring from the lower three sensors on the fresh tank and still the gauge shows 1/4 full. This tells me there is something wrong with the control system. Would any of you know if there is any adjustment on the sensitivity? It’s a Sergeant EC700 unit.
OldWomble
OldWomble
141
123
West Sussex
AS Kemerton XL
25 years
alternatively, has anyone ever ripped out the Sargent unit and retrofitted something that works?
Mar 19, 2022
7
9
Derbyshire, UK
Knaus ski ti
I’m a newbie
Hi. I’m having exactly the same problem and have also tried intense cleaning etc. but no joy. My question is, where are the level sensors and has anyone replaced or upgraded them. Would be great to have this working. It’s never been right!
May 28, 2024
580
2,172
Maspalomas, Spain
Giottiline Toscan 74
Well I thought that was normal on most, if not all, motorhomes. My fresh water level only shows 100, 75, 50 and 25% so we need to guess the real level. The grey water level is either 0 or 100%, but is easier to guess because it fills from the fresh water that we use. So when fresh is at 50% so is grey.
May 28, 2024
580
2,172
Maspalomas, Spain
But only if both tanks are the came capacity.
Grey is often slightly smaller than fresh as some fresh is drunk and won't end up in the grey tank.
Yes, mine are both 100 litres. We don't drink the fresh as we cannot be sure it's good here, so use bottled water for drinking and cooking.
Oct 7, 2013
6,119
38,419
South Wales
Swift Escape Compact
Since 1988
We are on our 9th motorhome over a period of 40+ years. Most of the fresh water/grey water gauges have been wildly inaccurate.
May 13, 2016
1,937
16,858
Elddis Accordo 105
eight years in theory, a newby in practice!!!
We have the same issue as most seem to have. Our van has a 90ltr tank and the way we deal with it is by using a 10ltr watering can to fill it from empty then use a 10ltr plastic bucket to empty the grey waste and have an educated estimate of the weight of the toilet cassette. We're never far out (y)
Nov 18, 2022
173
201
Holmfirth, UK
Elddis Majestic 135
I hold down the button for 30s then release for 30s then repeat that twice. Seem to get a reasonably reliable reading. Not exactly instantaneous :)
I also recalibrate it frequently (for luck)
Whale illuminated bars thing.
Oct 20, 2023
136
138
Scotland, UK
Auto-trail
Waste tank full empty or full likely has this kind of sensor:
Works well as it's clear of waste, or should be 🫣.
Fresh is from sensors up the tank:
Sensors can be checked individually. Pair with power (bottom lead) probe and a.n. other in container with water and check display. This should help identify the fault.
Feb 27, 2020
448
813
pilote diamond 783
2 years
In my pilote I have fitted krus resistive float level sensors, this connects into my victron cerbo, i can see to an accuracy of .5 litre in my fresh water tank, i can monitor this direct via bt, via my touch display or via vrm portal anywhere in the world. I can get level alarms via email or app alerts.
Two on Tour
10,796
55,691
Elddis Autoquest 175
Both our fresh and grey waste tanks are external under our van, and I have fitted Mopeka Pro wireless sensors to the underside of our tanks and these are very accurate and adjustable to suit the capacity of your tanks via the phone app.
May 28, 2024
580
2,172
Maspalomas, Spain
That's interesting, I need to look into those sensors.
Jan 9, 2017
79
52
Harrogate
tribute T615
Since late 2015
Not a problem unique to motorhomes. Have just hired a narrowboat for a week and on taking it over was was told by the boatyard chappie never to believe the freshwater tank gauge but to fill up every day. Was slightly disconcerted to find subsequently that the toilet tank gauges were similarly useless not changing from zero for the whole week!
