Water boiling, when you have an inverter
How do you boil water ?
  • Electric kettle (<2kw)
    Votes: 53 57.6%
  • Whistling kettle on induction hob (<2kw)
    Votes: 4 4.3%
  • Gas
    Votes: 50 54.3%
  • Total voters
    92
  • Poll closed .
And then you see cables like this Ian and think :unsure: OK
I know that it’s ok but my mind is always kind of, wow when you think of/see 300A being drawn.
Which are just crazy IMO, wait until there are some high resistance joints building up in some of these installations !!
It’s not crazy when the systems are designed/maintained properly; there are installations all over the world drawing way more than our vans will pull.
In terms of high resistance joints, as well as ensuring that recommended practices are followed (correct mating procedures and tightening torques), use of an infrared temperature gun can identify any developing issues.
Ian
Our small camping kettle is 700 -800w
On my battery app it draws 85 amps peak
Your kettle must be bigger than 800 watts as 800 watts at 12.8v (used 12.8 as that is generally on load voltage of Lithium) + 10% for inverter efficency comes to 68 amps.
Our 800 watt kettle in practice draws 67 amps.
Lithium is the game changer
I have dumped the Webber Q200 gas BBQ, for the Ninja Woodfire grill, as it cooks steak better, is smokey , and has a load of other functions, including air frying
A whole chicken in an hour, tasty, smokey, crispy, even better with a Tex Mex rub
We use so little gas now 👍🏻
It is off topic, but how good are those woodfire grills, they seem to cook everything perfectly and to be able to smoke cuts of meat is a bonus. We absolutely love ours. 😎👌
That is a very optimistic view, this kind of equipment will not get ongoing maintenance or inspections and there are quite a few bodgers fitting kit into motorhomes.
Ian
..... AND most of those systems are professionally installed at (usually exhorbitant) professional prices & are (usually) maintained irrespective of the operational costs !
As compared to most camper-van and motorhome installations which are often designed, installed, and (supposedly) maintained by enthusiastic amateurs or non-expert semi-professionals at the lowest acceptable cost to the vehicle-owner.
Comparing Professional-Cost "Apples" with Self-Build/Self-Install "Oranges" IS a misleading & meaningless waste of time, and I prefer to deal with the world and give my views or advice based on reality and practical experience ..... NOT on an "idealised fantasy" basis.
People are perfectly free to take note of or consider my posts OR ignore them as they see fit ..... YMMV.
If "nuclear cold fusion" units (OR other "upgraded future technology") ever become available for the home market or for the better off self-installer with deep pockets, I would still tend to listen to my gut and avoid parking within easy fire or explosion range of those vehicles whenever possible.
PS .... In over 50 odd years, I have NEVER met another motorhome or campervan owner yet that regularly scans all their vehicle's wiring with an "infrared temperature gun" in case of developing issues as per your post.
PS .... In over 50 odd years, I have NEVER met another motorhome or campervan owner yet that regularly scans all their verhicle's wiring with an "infrared temperature gun" in case of developing issues as per your post.
Wise words.
I added that statement just to be complete and with the knowledge that, in reality, they don’t really require maintenance as such.
Undoubtedly there are (possibly more-so in the ‘van-life’ community) but my response to you was simply pointing out that having high current systems isn’t crazy if they are designed and installed properly. Any system that isn’t designed/installed properly is vulnerable to failure; you can’t legislate for those.
As above.
I wasn’t endeavouring to compare standards between professional systems and self-builds, I was pointing out that high current installations are not ‘crazy’.
We haven’t met. 😎
Ian
Is that before, during or after your 10 minute wait for a cuppa?
We haven’t met. 😎
Ian
No, You & I haven't met ..... But as you seem to suggest that you "regularly scan all YOUR vehicle's wiring with an "infrared temperature gun" in case of developing issues" ..... It would appear to me that you are perhaps the ONLY (or perhaps one of the very few) of the more than 100,000 Members of MotorhomeFun who MAY do so, so it is hardly expedient of you imply or suggest it's a commonplace event, and you appear to be the exception rather than the rule.
Likewise, I've never come across a Motorhome/Camper Dealer that states & confirms that they carry out such a check whenever they do a "Habitation Check / Service"
I'm always keen to learn, so I'd be very interested to read posts from any other MotorhomeFun Members that regularly do such an " 'infrared temperature gun' in case of developing issues" with their vehicles.
Something of a non-sensical reply, Jim, as the post of mine which you quoted has nothing to do with a "cuppa".
Read the posts properly, please Jim ..... I already said in my earlier post that I have to wait about 7 minutes for a DOUBLE mug, NOT 10 minutes as you now suggest.
Why use a whopping 750w This is only 135w takes just 25 minutes and must be so much better for your batteries. :LOL:
Also, I diplomatically declined to post & point out the "One or Two Small Flaws in your earlier cunning plan, Baldjim" as you said earlier, but seeing as you asked so politely & non-sarcastically >>>>
A) >>> Your Recommended device will only boil ONE cupful at a time, so you would need ONE of them for EACH person that wants a cuppa which would multiply your power consumption radically.
B) >>> Based upon your statement that you like to boil your water on the floor of your motorhome whilst travelling at 70mph on the Motorway, I hate to think of the carnage & mass pile-ups that might ensue when your boiling open cups of water topple over and scald you & your passengers (and also possibly short out your Ultra-High Amperage cables & system). ;) :LOL:
So, given that most of us are not electricians, or electrical hobbyists. Why should we temperature scan our wiring? Where should we scan? There is a lot of it, how do we get to it all? When should we scan. How often should we scan? What are we actually looking for? What heat is normal, what should we be worried about. Do we turn everything on, use it, and then take the temperature?
I can get started right away as I do own an "Infrared temperature gun" but I ONLY use it to check trailer wheels for brake sticking, and sometimes my forehead if struck down with a bit of manflu. Thanks in anticipation.
You appear to be getting the wrong end of your stick, Jim .... and you are aiming at the WRONG target.
It is & was bigtwin that raised the idea and effectively implying that everybody should be doing it as a matter of course ..... So kindly redirect your Post AND Questions to bigtwin ....
I was the one arguing that it is extremely rare and NOT common practice for people to "regularly scan all their vehicle's wiring with an 'infrared temperature gun' in case of developing issues" as per bigtwin 's posts. .......... Like you, I would be fascinated to hear the answers to your queries from bigtwin.
Also, using an infrared temperature gun to check for "trailer wheel brake-heat" is totally irrelevant to my replies to bigtwin about vehicle WIRING, and likewise for checking your forehead (UNLESS you're a cyborg :LOL: )
It is & was @bigtwin that raised the idea and effectively implying that everybody should be doing it as a matter of course ..... So kindly redirect your Post AND Questions to @bigtwin ....
I was the one arguing that it is extremely rare and NOT common practice for people to "regularly scan all their vehicle's wiring with an 'infrared temperature gun' in case of developing issues" as per @bigtwin 's posts. .......... Like you, I would be fascinated to hear the answers to your queries from @bigtwin.
Ah gotcha. I did misread it, I can see now that it's not your Infrared Temperature Gun, it's bigtwins. :blush:
DOeSn’T EveRy BoDy MaKE tAe eN rOUtE?
Erm, I have one and scan the wiring occasionally. 😬
More than just the Water boiling on this thread.....let's get back on topic...it did start so well and very interesting..
Did I; where?
I didn’t.
I did no such thing.🤷‍♂️
That’s good advice; consider taking it.
Ian
I am with Bobbejaan on this, high current installations will be fine if well installed and maintained.
However that condition will rarely exist in the motorhoming World.
I know about high currents, the only thing I have been trained to do is be an electrical fitter in Fawley power station, we had some rather special kit for checking for low resistance connections in cases of high current flows (at the bottom end of the ranges used in these high wattage inverter installations), I guarantee that no one uses such equipment in MH installations and the equipment was not a fancy DVM.
I hope that I am wrong but the potential is there for problems.
Is that not exactly what I said in response to your assertion that it was crazy to have those currents in a MH. Quoted below for clarity:
In self builds perhaps but a rather damning accusation against MH manufacturers as a whole.
Me too, I did my apprenticeship in a power station and subsequently worked on submarines where they have rather large battery banks.
There’s always scope for problems with electrical systems but this risk, as I asserted at the start of this little exchange, is minimal if they are designed and installed properly. 👍
Ian
Ian
Ian
I think we are broadly in agreement, I just think that you have more faith in the manufacturers and installers than I do.
Best Regards
Barrie ex CEGB electrical fitter (best thing I ever done)
I have an infrared temperature gun but I don't use it, I prefer my home made one it's called my hand. I feel the cables & joint, slightly warm under high load is fine it's feel hot I investigate and find out why. 😊
Ian
I replied to the context & phrasing of your original post above aimed at MotorhomeFun members ... Which directly compared "installations all over the world drawing way more than our vans will pull" to "use of an infrared temperature gun can identify any developing issues." and which implies that members should regularly check their vehicle wiring such a gun to "identify developing issues", and that is simply scaremongering towards newbies OR less experienced/knowledgeable members.
Finally, I am still awaiting in fascinated anticipation to your answers to Jim 's questions for you, namely >>>>>
See your keypad is still playing up!
