Victron Inverter/Charger 12/1600/70 and Mk3-USB device settings - training and password required ? (6 Viewers)
Jun 7, 2023
29
22
Burnley, UK
Carthago E-line
Hi,
I am ready to install my inverter/charger and have purchased a Mk3-USB in order to configure it. But when I run the Victron Connect App it says I need to do a training course in order to get a password to be able to set the inverter/charger ?
Why ?
All I want to do is ensure it is set to a lithium battery profile and have it plugged in to the Multi-control panel inside the camper so that I can amend the input amps and 'soft' turn it on/off/invert etc. Why do I need to do a training course for this and where ? It's just an rj45 from the inverter/charger to the multicontrol.
Have I missed something here and being stupid in my query ?
Every other Victron device I have is plug and play bluetooth, so why not the inverter/charger ?
How do I set this thing up ? If it needs a training course, then why did the kit supplier not tell me that or even check I was qualified to install it before selling it to me ?
Can any one enlighten me as to what dip switch settings I need to make this work ?
Cheers in advance.
MarkHoughton
Jun 7, 2023
29
22
Burnley, UK
Carthago E-line
Try asking on this Facebook page, it's titled Victron Powered Camper.
On facebook i just got "Sarcastic" replies as I already have asked on that forum with "The password is maybe zzz or ZZZZ" and If i am not smart enough to google what the password is then maybe i should not be touching electrics.
My query is that all the 'install videos' of self builders ( in the UK ) just show them connecting the cables, turning it on and smiling oh great my inverter/charger is working. None of the videos explain OR mention that it needs configuring or what settings are suitable for the UK and the average LiPo4 battery that most people seem to use.
MarkHoughton
Jun 7, 2023
29
22
Burnley, UK
Carthago E-line
Is this link of any help?
Hi, not really... it just gave me this. thanks anyway.
Dec 2, 2019
3,887
8,593
Amersham
van conversion
Since 2019
Hi,
Why ?
Cheers in advance.
You do not use mk3 to usb with victron connect app.
You need windows, go to victron dot com, downloads, and download VE config tools. Use VE config 3, and plug in your MK3 usb the click port selection. Away you go.
You can use victron connect app, but, with a VE bus to BT dongle, the small green box you plug into multiplus and then you connect to that with the usual victron connect app. The settings here are limited, and as you already have the MK3 use the victron config tools.
Make sure when you plug the rg45 cable into multiplus, you plug into the VE bus, not CAN, they both the same but make sure you plug in the right one.
