- Nov 17, 2020
- 60
- 39
- Just Looking
So, I've done a lot of research with regards to using this unit and changing leisure battery to Lithium.
As I understand (confirmed by apuljack) the unit can be used in Gel setting to charge Lithium batteries for short periods of time (whilst on hook up) but not for longer times like overwintering due to the high float voltage. On hookup EBL 30 would still trickle charge the engines AGM too but on the GEL setting?
Would this do harm to engines AGM? Can this be disabled with fuse removal?
I can/will add solar/controller with Lithium specific charge settings for when off hookup, I think that will work OK??
The only problem I see is when the engine is running, it's not possible to disable engine charging/linking of leisure battery, Apuljack tell me the unit will have to go back to them to have this disabled. A simple fuse removal is not possible.
If we buy a Hymer with the Electroblock battery booster the problem should be solved as this unit has a Lithium setting.
Help and advice please.
