No he has simply upped the price because he knows he is still much cheaper than the competitors
No he made it clear take it or leave it.Or maybe he gives a price based on your postcode?![]()
I'm assuming that the weight offered by John entails the rear 2400kg Alko being raised to 2500Kg and the front 2100kg being raised to 2250kg which I can only guess is due to the previously fitted VB springs.The 'new' price may reflect the fact that more and more people are asking him to do the work so whereas before it might have been the odd one now and then which he fitted in, as he's having to do more now it will take him away from doing other things which probably pay more, so the cost has to be made more viable for him. I did think he was doing it a bit too cheaply anyway!
My fault I suppose for letting you lot know about him in the first place!![]()
Did you use the new address I posted as his original one had been hacked, you should use the one starting truckcon ...I sent him an email if he responds he's better than svtech who I emailed 3 weeks ago and still no response. If he responds he'll get my business aschool and when I need it.
Thanks no did not see it will receive send email. ThanksDid you use the new address I posted as his original one had been hacked, you should use the one starting truckcon ...
You're using predictive text aren't you!Thanks no did not see it will receive send email. Thanks
Damn phone yeah I changed recently need to learn to reread before I post lolYou're using predictive text aren't you!![]()
He's raised my rear axle to 2650kg front has remained unchanged.Luckily at 4250kg I'm in no hurry for an up plate but for £142 I'll happily take another 500kg after my holiday
If only SVTech had a two tier fairer pricing system, their loss good luck to John![]()
I just retyped it and covered it with some sticky back plastic and stuck it in the camper. It's not the plate that's important but the V5C document with the weights on.I have to say I was not impressed with the sticky label plate provided by John and it looked like his printer was low on ink BUT an acquaintance of mine has made me some on different materials. I'll post pictures when I get them and if anyone wants a similar service I'll put you in touch.
You can buy laser printable vinyl on Ebay, its not expensiveHaving seen my mate he has said that the one I have is actually a better material being polyester backed. So I trimmed off all the surplus and it's not bad
Very useful mateyYou can buy laser printable vinyl on Ebay, its not expensive
