TyrePal TPMS Safety System For Tyres 20% Discount Code For Funsters
Been on charge all day, the display is still pretty dim. I have dropped TyrePal an email to ask if there is a way to improve the brightness.
The old monochrome version did have a manual brightness adjustment but the later ones don't have this. On the current Solar Colour monitors there is some adjustment (two levels) which is automatic - in low light or darkness it dims to prevent dazzle but instantly becomes brighter in sunlight. Can test it by positioning it in a sunny spot then put your hand over the solar panel & the display should dim.
Response from Tyrepal
Unfortunately, the display brightness cannot be adjusted. The display is really for occasional reference, as it could be a visual distraction whilst driving. Try to place the monitor in a dash shelf/recess. If there is a significant change in tyre pressure or temperature there will be a loud audible alarm from the monitor.
Bump for this thread for background info for all those posting recently with queries about TyrePal & the Fun discount code can be found here Broken Link Removed (y)
Hi Wombles
Code in the link above hasn't worked for me today. Is it still valid? Is it for the Prima Leisure site you get bounced to from Tyrepal?
Ian
Hi Wombles
Ian
Thank you for the update - looks like TyrePal have stopped direct selling so the code is no longer valid :(
CAMC members get discount off Prima products which includes some TyrePal https://shop.caravanclub.co.uk/search/?term=TYREPAL
