If there’s a current discount code would be pleased to hear about it
If you mean Fun code there is but 15% not 20% - see post #91 - currently don't know C&MHC but it has been less than our Funster discount in recent yearsIf there’s a current discount code would be pleased to hear about it
Glad you guessed well & will travel safer nowHi Boys N Girls, I'm in the middle of ordering one of these "new and improved" tyrepal pieces of kit and thought I'd try the old voucher code MFRVOC19TP , well it doesn't work any longer HOWEVER try MFRVOC20TP ........ RESULT!! £14.85 discount!!
Cheers and stay safe!
Russ
We've never had a problem with any TyrePal monitors being permanently on the dashboard but a couple of Funsters have reported issues with their solar units so probably wise to put them out of direct sun in extremely hot weather when not in use.Does it stand the heat when mounted on the dashboard under the windshield?
Good to hear that the Fun discount code was a substantial saving for youThank you for sharing the discount code RustyRuss, you just saved us £64.00 on the 10 sensors and monitor kit
John n Kath x
There are several things that get too hot inside vehicles in the sun.Does it stand the heat when mounted on the dashboard under the windshield?
I left some Crocs in our conservatory in direct sunlight for a day & the tops distorted & shrunk - won't do that again! It's surprising how hot things do get through glass.There are several things that get too hot inside vehicles in the sun.
I remember borrowing a friend’s cherished record & he didn’t like what the sun had done to it left in my car
But the Tyrepal on it’s none slip map hasn’t shown any likelihood of getting damaged.
I do pick it up & move it away from the dashboard when not in use tho![]()
Good to hear that - thank you for the feedbackSaved £20 with that code - MFRVOC20TP
Yay!New code just worked for me £19.80 discount. Cheers
Just bought one of these with the discount code. Will see how it performs on our next trip with the mh.TyrePal https://www.tyrepal.co.uk/home/ have kindly agreed to a 20% discount across their whole range for Fun & RVOC members with code MFRVOC19TP
We wouldn’t be without TyrePal TPMS fitted on both our car & motorhome (even though they have already have the Ford & Citroen factory fitted version) as the display makes checking all the tyre pressures easy (including the spare with an extra sensor) & the early warning it can give could help avoid an accident. Our motive for negotiating the discount & posting about this accessory regularly is to encourage Funsters to fit some form of TPMS & hopefully travel safer as a result.
Other benefits of keeping a close check on tyre pressures include better fuel economy & road handling plus some insurers (including C&CC & Caravanguard) now offer a 5% discount for motorhomes fitted with TyrePal. There are cheaper versions available but mixed reviews on these online & we have had TyrePal fitted for several years now & always found it a reliable safety product & there is good back up technical support if it's ever needed.
Thank you for posting - it was meant to last for all of 2020 so will try & get it reactivated.MFRVOC20TP seems to have ended
- Sorry, this coupon is not applicable to selected products.
Thanks Wombles. I'll give them a call next week. I'll feedback how I git onDerry Wilson Suggest contacting TyrePal to check why that may be happening & whether replacement is needed.
