Spoke to the owners of TyrePal a couple of weeks ago as we previously had a Fun discount code for several years but now they are selling exclusively through Prima so sadly no Fun discount is possible. It is an excellent product that we & many other Funsters have had fitted to good effect for many yearsJust been on the tyre pal web site and they offer discounts the the 2 big clubs in the UK but say that if any other organisation wish to apply for a discount they can contact their sales at sales@tyrepal.co.uk.
Would Jim consider doing this, especially as members are providing excellent feedback on this product?
Our experience of Prima buying some Colapz silicone mats was a long wait but TyrePal assured us that they make sure their products are always in stock at Prima so there shouldn't be such problems.Thanks for the response. I have been on the Prima site and trust pilot show that 1 in 8 people rate Prima at 1 star for customer service. Saying items are in stock then making customer wait months with little of no comms. Taking a customer money them making them waitr and not communicating is too much potential hassle for me.
Tyrepal recommend turning it off when not in use to preserve battery life but as others have said, the solar keeps them very well topped up without ever having to charge them.Can I do a small thread hijack and ask if the solar monitor unit charges well enough on the dash and if the unit can be switch off when not being use?
I bought tps kit from eBay which claimed to be up to 5.5bar, But would not go above 4.7 bar don’t waste your money get a decent set.Are the fleabay ones as good as tyrepal?
I don't know much about them until now, but looks an essential but of kit
We had ours for 5 years, until we sold the van, only changed the batteries once, changed the 'o' rings at the same time, never had a leak.Hi how do you stop the sensor? leaking air, n/s/f has been losing a bit of air from 5.5 bar to 4.7 bar according the the display , was also thinking of removing all of them ,what do the forum think yes or no .
Mine did the same after a lot of use, replaced the o ring seals and they are fine now.Hi how do you stop the sensor? leaking air, n/s/f has been losing a bit of air from 5.5 bar to 4.7 bar according the the display , was also thinking of removing all of them ,what do the forum think yes or no .
I have had Tyrepal fitted for almost two years now with no problems whatsoever.
I haven't needed to top up our tyres for over 6 months and the pressure remains constant.
I change the batteries once a year and also changed the "O" rings about 6 months ago, but to be honest I don't think they needed to be changed. It is a great system that I wouldn't be without.
As others have suggested, try changing the small washer/o ring that seals against the top of valve.
Also, how do you know that it is the sensor? You may have a slow puncture.
We had same issue with front off side thought it was tyre changed rubber o ring ok now, look on tyrepal web site for replacement, cost £4.00 for 4Hi how do you stop the sensor? leaking air, n/s/f has been losing a bit of air from 5.5 bar to 4.7 bar according the the display , was also thinking of removing all of them ,what do the forum think yes or no .
It’s better than nothing, I was given early warning in a Kia Sportage and was able to pull over in plenty of time so as not to damage the tyre. Roundabouts were never a problem.My wife's car uses the difference between wheel rotations to flag a low pressure alarm, this perhaps would not be effective after two many roundabouts?
I've tried 2 sets of Ebay, the first failed after a year, the second didn't work properly. You have to check what your ordering, as most don't register high enough psi. Fine for a car, but not commercial vehicle. Although they look similar to the Tyrepal units, it's my opinion that Tyrepal are manufactured to a far higher standard.Are the fleabay ones as good as tyrepal?
No need to rebalance your wheels when fitted.These sound like a useful risk reduction tool. How much mass do they have, do you need to re-balance the wheels after fitting!
I usually put a drop of spray oil on the thread of the valve to protect itI found with a previous set that the caps can corrode and get stuck to the valve thread so a wee dab of silicone grease to help keep them free.
yes as thats what mine are onDo the TyrePal sensors fit on the Ducato factory fitted high pressure valves OK. They have 10mm of thread above the nut on the high pressure valve stem.
Is this enough for the sensor plus lock nut?
Thanks!
