Now that would be taking thread drift way too farLesson to self. Read the title correctly. I read....
TrumP dis-appreciation society
Was expecting to see the idiot had been up to his usual shennanigans again
I'm having similar major problem with my Truma DE, now in full lock out, and looking options, can I ask where did you buy your original older model from and how did you make sure it was the older model and not the next generation model ?I had a Truma D6E Next Generation fitted to my van for 6 months - it was very temperamental- you had to be careful how to power it down, I got several strange error messages about “unexpected values”, it sooted up for no reason, the fuel pump was very loud and it dribbled condensate down the outside of van. I was reduced to carrying the expensive diagnostic unit arround with me just in case it locked me out after 20 errors. However it did heat the van and water quickly!
Then I replaced it with the original older model - super quiet, no error messages, no dribbles down the side of van - good old Truma just works well. Not as fast at heating the water and uses a bit more power on electric hook up.
Best up (down) grade I have done! Apparently the guts of the old model was made by Eberspacher but during Covid Truma went ahead and designed there own next generation one.
I just checked and I bought my AVS30 from Sollatek UK via Amazon for £79.99.I havent read other posts so it may have been mentioned
If you recently paid £50 for an AVS30 it is very likely to be a chinese counterfit/copy and not genuine even a fire hazard
I have had the unfortunate pleasure of having bought one and they are quite different internally
Same here, plenty for sale on EBay for less but wouldn’t touch them,I just checked and I bought my AVS30 from Sollatek UK via Amazon for £79.99.
Totally agree, I should never have had the gas/electric version fitted. The electric elements fail every time. Been there before and should have known better.Not entirely sure if this will fall foul of the 'review section only' rule but is anyone else really starting to hate Truma?
My boiler packed in a few months back, it was built when they made them good so lasted many many years. I thought for a long time on what to replace it with and despite numerous threads on here stating various fault codes being received I still decided to go with them and had their 4E fitted.
The thing is constantly throwing up fault codes. The fitters have been great and have me back round for anything they can do to help but these new boilers just seem to be over sensitive. Air lock?... fault code... connect to hook up? ... fault code.... disconnect from hook up? .... fault code.
To add balance I should add that after the initial errors, it has worked perfectly on gas only. But now I am plugged in for some reason it is throwing a hissy fit.
Discontinue spare parts and force the customer to buy new. Issue is their new units seem absolute garbage.
Anyone else had bother with them?
Thanks for the info.Yes locking you out is the most annoying aspect! If it sees multiple errors with the fuel heater (even if they seem spurious) it locks you out completely so no heating at all not even on electric. Then you need a £600 diagnostic unit to reset count and get it going again!
I don’t have any recommendations on where to get the original version - a quick internet search seems to bring up several options. The old unit is a similar size so was easy to fit in the space it took a few hours to switch over units.
Good luck.
I like my 16 year old truma..you can't adjust the temp when on ehu so it's 70deg or nothing...it heats up in about 5 mins...works great on gas, where I can adjust the temp....It's just a boiler!
What ever happened to just switch it on and off as required?.......Like my 14 year old Truma.
