The 12V fuse on the accessible part of the circuit board is another candidate. Have you checked it with a meter to see if there is 12V on both sides of the fuse? If there is 0V on both sides the fault will possibly lie in the circuits leading to the boiler.Yes I have
Great to find information on older threads.As Allanm says the top row of icons disappears when everything is off but you should be able to select from the lower row as shown in his pictures. However I had a similar problem as your friend when my unit was new. The fault was simply that the rotary control knob had slipped too far down the shaft of the controller and this was stopping the push function from selecting anything. Having pulled the knob off the shaft I found all the functions returned to normal, I then put the knob back carefully making sure it was not too far down the shaft. If I push the button too hard it sometimes repeats the problem, I have learned to live with it.
Hi, I know this is an old post but I have tried some of above posts and now I have no power to the iNet panel after try the above one?Have you tried the appliance search procedure? When I installed my iNet box I discovered that the control panel does not automatically connect to new devices on the network and needs to be set to discover them. If your control panel has somehow forgotten it’s connection to the boiler it might need to reconfigure the network. This is the procedure.
Went out to our Adamo this afternoon. I was going to start the wiring of the Victron shunt. I went to put the heating on forgetting I had yet to fill the newly fitted Gaslow system. Truma panel came up with a gas error. Tried to get it to switch to mains electric, forgot how to and reset came up while I was basically trying to work it out. I foolishly selected reset and lost all the Icons! For the life of me I had no idea what to do next until I searched the MF Forum. Such a great fountain of combined knowledge. Followed the above and some 20 second's later all was back to normal. Thank you for taking the time to post. Regards to allHave you tried the appliance search procedure? When I installed my iNet box I discovered that the control panel does not automatically connect to new devices on the network and needs to be set to discover them. If your control panel has somehow forgotten it’s connection to the boiler it might need to reconfigure the network. This is the procedure.
