Northernraider
- Jul 30, 2017
- 34,779
- 258,044
- N&B Flair 8000ib
- AirOn and off since 95
Aye I've been having a lookA couple for sale on this forum,,
This should be ok as long as you don't use petrol to start the fire. (Diesel is probably ok). I'm curious though, is this going to be used for space heating or hot water too. If water, maybe you could add a brass bed head and footboard following the Steptoe design.Think I will be going for an A frame to tow in UK - although I'll carry on with research before a final decision (don't need this until next year).
Thanks to all for your help - it's been remarkable civil
Now, I'm thinking of adding a wood burning stove to the back of the van This will be used in transit as well, but won't be left unattended, as the Missus will be in the back whilst travelling.
She will be on a side facing seat, so no need for a seat belt making it an easy job to stoke the fire.
Thoughts![]()
... what on the 'thread postings' or popcorn????Oh no! I have only just found this thread. I will just have to start at the beginning and binge.
It doesn't speak French.....?What's the issue with the dog in France?
That's could be a reasonable excuse but does it speak English anyway? Not if it's a staffie.It doesn't speak French.....?
I have known this to happen to a Smart for Two on an a frame. Usually started by a pot hole or mini roundabout hump but only at slow speed and when pulling away on a turn. Can be cured by damping the steering wheel.I assume this was due to the front wheels of the car hitting potholes etc and turning/snaking a bit
Our van is registered at 3,650Kg and on the weighbridge the other day our rear axle came in at 1,900kg (max permissible is 2,000kg). Am I stuffed with only having a small allowance remaining in terms of tow bar (35-40kg) and whatever the extra downward force of the a-frame produces.
There should be negligible downward force in the towbar from an A frame. Just about half the weight of the frame itself.Basically yes.
& you can tow at up to 130km/hr in France as well.Frighteningª!Don't think I've mentioned this before, but about a week ago we were travelling behind a French MH with a small car on an a-frame (can't remember what it was now!) and it weren't half moving around from side to side as they drove along, I assume this was due to the front wheels of the car hitting potholes etc and turning/snaking a bit ... didn't make for easy watching!
The A frame weight doesn't count as part of towing vehicle weight but would only put an additional download weight on to the rear axleThat's all very useful stuff - thanks guys.
Our 1,900kg rear axle weight included the garage items plus full water @ 135kg/litres. We can run quite happily with only 50-litres in the tank (tank behind rear axle) so in theory I could bring at least another 85-100kg to bear.
If I have circa 200kg to play with (Nick - I note your point regarding axle weights) then what would be my weight considerations:
1. 35kg minimum for tow bar.
2. 13-20kg for A-frame.
...........are there any other weights to consider or any other weights that would affect my rear axle (or should I just add half the weight of the A-frame again).
Thanks All,
Andrew
The download on the tow ball from an A frame is tiny. It would be about half the weight of the A frame itself. No load imposed from the car as all of the car weight is taken by the car wheels& you can tow at up to 130km/hr in France as well.Frighteningª!
