- Aug 18, 2014
- 26,872
- 165,276
- Transit PVC
- 16 years since restarting
& people wonder why they aren't legal elsewhere in the EU
Which is just under the max legal height.There is a sticker on my Caratow frame which actually states the Ball Height must not exceed 16"?
I wasn't sure whether a bungee would be enough to stop it going past a 1/4 turn - obviously it is. Tyre scrub shouldn't be an issue anyway given the limited number of times a very sharp turn is made. Here's proper tyre scrubThe bungee is actually from the seat frame to the bottom of the steering wheel. On the smart car up to 2014 If the steering wheel is a triple as is on mineThe bungee strap goes between the lower section back to the seat. As regards a full turn left or right..it is physically prevented from allowing the steering wheel to turn through 180 degrees. This in itself prevents the steering from chattering or 'wobbling' because of t preventing movement beyond a point to cause it.![]()
The bungee can or could break i am sure but to be honest...how long is a piece of string? It will give to the point of return and then reset. We have been around islands and tight turns of varying types. It has not failed us yet . That does not mean it will not of course.
Then ...I would buy a new bungee!
If there is a fault...then it comes down to the scuffing of the tyres on the front. Why?.......Because the steering wheel is prevented from going past a point to allow a full turn . With the strap /bungee attached...it prevents to the point of allowing a turn but not a full lock turn.
Hopefully my opinion will not come across as if 'I am God' on Smart cars and tow frames! Trust me ...I am not. I just feel comfortable with what we have and Therefore we are more than happy with how it performs
Kind regards Kev
& people wonder why they aren't legal elsewhere in the EU![]()
Can I just point out, That the Smart shown likely has a Manual Gearbox?. Virtually ALL manual cars can be "flat towed". It (the manual option) became available Circa 2014. I KNOW it was available in the American Market.
it cannot be towed under any circumstances as the gearbox will have no oil circulating
Most, if not all, manual FWD vehicles still use 'splash' lubrication. Most front engine RWD cars use splash lubrication but a few have a pump mainly to ensure rear (prop sleeve) bearing lubrication. All Fortwo Smarts are rear engine RWD - I'm not familiar with Forfour Smarts.That I did not know, but would effectively apply to nearly ALL manual cars with Front wheel drive.
I have the auto 453 and it certainly has a brilliant twin-clutch gearbox - probable the best, auto or manual, I've driven. I tow it on a trailer.The 453 is a big leap forward in driving pleasure from the 451
That is purely because the EU is so far out of step with the UK and other Civilised country`s. And Who`s legal systems are based around the warped thinking of a little dictator, who got a good hiding at Waterloo.![]()
Reversing an "A" frame is not something recommended. The stresses imposed on the frame, chassis (both vehicles), and tow bar,
& you are on the side of the road trying to convince the Guardia that it is a "trailer"![]()
I wasn't sure whether a bungee would be enough to stop it going past a 1/4 turn - obviously it is. Tyre scrub shouldn't be an issue anyway given the limited number of times a very sharp turn is made. Here's proper tyre scrub.
