Timing belt replacement. (1 Viewer)
Hammie
467
278
Neismann & Bischoff Arto
newbie/2015
Hiya. Has anybody used a company called Redstonefleetcare in Redhill Surrey? I’m thinking about getting them to replace the timing belt etc on my beast. I’m feeling a bit nervous as it is a big job and can go horribly wrong but Fiat quoted £1,500
Hammie
Hammie
467
278
newbie/2015
Which one Lenny was it you who had it done last year For £1,000
Redstonefleetcare said about £650 but it could be more if there is a problem with the tensioner bolts
Lenny HB
54,316
153,760
On the coast in West Sussex
Hymer B678 DL
Nope £573 at Adams Morey Portsmouth.
I think it's a couple of hundred more now, they were taken over just after I had mine done and labour rates shot up.
Hammie
Hammie
467
278
newbie/2015
Thanks I’ll get a quote from them
Hammie
Hammie
467
278
newbie/2015
Hammie
Hammie
467
278
newbie/2015
Duck Turpin?
Hammie
Hammie
467
278
newbie/2015
£738 at Adams Morey Portsmouth, last week C class, place absolutely chocka with work but booked in 3 days.
Well that doesn’t sound bad at all as they are Fiat main dealer. What age is your van please?
Hammie
Hammie
467
278
newbie/2015
Hammie
Hammie
467
278
newbie/2015
Sorry 19 years finger trouble
Jan 1, 2014
576
1,348
France
Pilote G691 LCE
Since 1974
Which Fiat base is your van?
Hammie
Hammie
467
278
newbie/2015
Jan 1, 2014
576
1,348
France
Pilote G691 LCE
Since 1974
The 2.8 is an easier engine to change belt and associated parts than the later ones, add to that it is not so essential to change the water pump, I'd suggest a reasonable price from a competent non franchise company would be in the £5-600 region for your Niessman
Hammie
Hammie
467
278
newbie/2015
Bottom left of the post you'll see Edit, just click on that and make changes you wish, but you only have a limited time to do so.
Thanks for both inputs. I was trying to delete the double posts but it won’t let me.
Riverbankannie
10,739
62,661
Bristol
IH 630 RL PVC
Hammie ,if you have left it too late to edit your post, send a conversation to Jim, he will oblige in these cases and remove it for you.
Hoovie
1,249
1,689
Autotrail
Tensioner and idler pulley's should be replaced at same time as belt regardless of condition.
For what they cost it's not worth the risk.
He is meaning the bolts not the actual tensioner I think.
If the bolts won't budge there is a danger of them snapping if forced. An expensive outcome! Fiat have a special tool that apparently can avoid and resolve this situation but that involves additional cost.
