Before during and after pics please?
Good news Paul.
Well done you - obviously the poem? hope you're celebrating tonight.I would never have believed it, permission granted
Just shows you the architect knew what he was on about
Good news Paul.
Nice to see Blue Knight posting as well?
Defo the poem Paul. Good luck with the buildYes and I thought it wouldn't get permission, I wonder if the poem swung it for me
Thanks Debs, yes the poem was the deciding factor, it must have melted their iron hearts
Yes a few drinks already, I must be celebrating,I've already kissed Caz tonight
I understand the steel rebar but but what do you mean about the shuttering aspect?If the wall is for a garage and below ground you could shutter and pour a concrete wall with rebar reinforcing, cast straight off the floor. Then tank the inside to stop damp penetrating through the soil
the builder makes a plywood form, basically a long box, that is then filled with concrete. When it sets, remove the plywood and the concrete when set is many times stronger than a block or brick wall. This removes the need for building piers, which would project into the garage spaceI understand the steel rebar but but what do you mean about the shuttering aspect?
Problem is the external wall which you can see must be reclaimed brick to match the housethe builder makes a plywood form, basically a long box, that is then filled with concrete. When it sets, remove the plywood and the concrete when set is many times stronger than a block or brick wall. This removes the need for building piers, which would project into the garage space
Planning permission was granted after such a long process, it’s the next Dale down, Teesdale.If you are begging Durham County Council i wish you every success. Looks like your remoteness is possibly up Wearable.
Best of luck.
Are you sure it was Building Control dictating what materials you can use? I’m a Building Control surveyor and we can’t dictate finishes unless it is a structural issue.I was "in consultation" with East Riding Planning for better than 8 years. We had bought a 1920`s wooden "Bungalow" that had been built on strip footings. Post war it had been Covered in Chicken wire and rendered.
Due to the condition of the foundations we applied for what is known as a "one for one" swap. The first plans where rejected Because they did not like my idea of a "Ranch" style Chimney!. We re-jigged and then they would not allow a Frosted window facing the road!. This went on and on and on. We proposed they rejected we finally reduced the floor plan and designed with an "attic" upper floor, which moved the build back on the site. And got permission that was about 6 years in. The next step was building reg;s. Facing brick?, Ah yes that must be same as original. "What Chicken wire and render?" Oh, Sorry, well submit a selection of bricks.? "eeny meeny miny mo". Roofing, Ah yes slate? You gotta be kidding?, seen the price of welsh slate?. Oh Ok grey concrete tiles then?. This too went On, and on, and on!. In one respect we where lucky, I was still contracted and working and living in Somerset during the most of this period. Eventually we got it done, while living onsite in our R-V for 2 years.
Planners?. If they had brains they`d be Dangerous!.
It’s Linseed oil paint from Oricalcum Andrew I’ve forgot the colour now. They should be finished the foundations walls and floor in a week or so I am currently obtaining quotes for the timber garage part.I would hate to think just how many tonnes of soil has been removed to get to that stage - looks to be a big job Paul.
When are you hoping to have it all finished?
I like the garage door BTW; Keswick Green by any chance.
No definitely not on there.Might have been mentioned before but was your house on Escape to the country? Looks very familiar !
He has just said the builder I would be better stepping the wall up as the timber garage would be below the side and back wall level otherwise but that would be more complicated to do the timber but on top.
Anybody with recommendations for bespoke timber garages?
Possibly know someone for a timber building, if you let me know what you are looking for I'll ask him.It’s Linseed oil paint from Oricalcum Andrew I’ve forgot the colour now. They should be finished the foundations walls and floor in a week or so I am currently obtaining quotes for the timber garage part.
Thanks, 8.7 metre long, 3.6 metre wide, total height 4.1 metre, height to eaves 3.45 metre, doors 2.9 metre wide and 3.26 metre heightPossibly know someone for a timber building, if you let me know what you are looking for I'll ask him.
No image but rough plan, as long as those measurements are adhered to then anything will do, I just need to be careful of the colour, even if no windows but just the openings then I can get windows later.Ok, do you have an image of what you are looking for?
Try BTL Timber at Toronto near Bishop Auckland. I've had many sheds from them and always a quality job with good service.It’s Linseed oil paint from Oricalcum Andrew I’ve forgot the colour now. They should be finished the foundations walls and floor in a week or so I am currently obtaining quotes for the timber garage part.
