Paul and Kate
How old is your firestick Manic.Been watching Now tv on my firestick with no problem.
Bought 24th November 2020 and it’s the 4K versionHow old is your firestick Manic.
Ours is the 4k but 3 yrs old.Bought 24th November 2020 and it’s the 4K version
We tried it for a weeks free trial.Strange because I had a free trial on Now tv entertainment and cinema pass over Christmas and the entertainment again in March to watch the final series of Game of thrones.
Also interesting if you try and cancel a pass rather than renew they offer the pass at a reduced rate for 6months.
Have you got a link pleaseAn offset bend at screwfix for the princely sum of £2.79 fits in the water fill point perfectly no need for three hands now when filling from containers 112 degree bend .
Sorry Paul I am not able techwise but . 112 degree offset bend round white floplast 68mm should find this item at the screwfix website .Have you got a link please
How about this from toolstationHave you got a link please
Very tidy Jock but those pics cannot be of your garage ...Very recently, I bought..............
2 x new garage door gas struts @300N each.
1 x new side locker gas strut @ 220N.
2 x new drop down bed gas struts @ 1900N each.
Fitting the latter two stuts looks like a nightmare of a job due to restricted access, as they need to be fully extended for fitting.
2 x Kamala Cargo Retaining Bars, which will be used with the aid of a ratchet strap, to secure our bikes to the wooden rack, and prevent any forward movement when travelling. A Fiamma or Thule bike rack, wasn't a practical option.
Once locked at the closest height/width required, the bars are then locked in position with finer extension adjustments being applied by twisting the bars clockwise, until the required tension is achieved.
View attachment 496983View attachment 496984View attachment 496985View attachment 496986
Cheers,
Jock.
Ha ha Brian. You wouldn't do well on The Krypton Factor.Very tidy Jock but those pics cannot be of your garage ...
Oh yes, I need to go toHa ha Brian. You wouldn't do well on The Krypton Factor.
Check out the clear plastic box with the grey lid.
There's a couple in there with your name on them pal. See you and Joyce soon.
Cheers,
Jock.
Only the one Brian?Oh yes, I need to go to View attachment 497026 I can see them now and look forward to cracking one open with you very soon.
... at a time Jock.Only the one Brian?
Jock.
I recently fitted new struts to my bed, as you say struts have to be fully open. I did mine but afterwards looking at the Hymer brackets , it looked like you could support bednon dash and remove arm and then rather than lift whole bed , just lift bed arm.(ignor black bar, that a tool I made to help put strut back on pin)WFitting the latter two struts looks like a nightmare of a job due to restricted access, as they need to be fully extended
Thanks berni. Yes, I have used similar inside fridge/freezer trailers, and know what you mean. These are a bit like Acrow Props in the way that they adjust.JockandRita be careful with those bars you can exert tremendous pressure turning those screw threads.
Thanks for that Manic. Much appreciated.I recently fitted new struts to my bed, as you say struts have to be fully open. I did mine but afterwards looking at the Hymer brackets , it looked like you could support bednon dash and remove arm and then rather than lift whole bed , just lift bed arm.(ignor black bar, that a tool I made to help put strut back on pin)
Mine had sloppy nut and bolts, which I replaced nylon nuts on and I uprate the struts from 1700 to 1900.Thanks for that Manic. Much appreciated.
I've saved that photo, and will refer to it when the time comes to do the job.
Re the drop down bed in our old Hymer, I thought the struts needed replacing, until I read about the 40lbs torque which should be applied to the nylock nuts, (which I replaced). The bed worked a treat after doing those.
Cheers,
Jock.
What licence do you need for that please?This week I ordered an electric scooter to live in Hymer’s garage for getting out and about when we are pitched upView attachment 496713
I’ve got a full motorcycle licence but if you have a full car licence and take a one day CBT you can ride it on L plates. There is a lower power version that you just need car licence and L plates.What licence do you need for that please?
I have full motorbike licence, but thought that it did not cover these. Has the law changed to allow electric bikes now?I’ve got a full motorcycle licence but if you have a full car licence and take a one day CBT you can ride it on L plates. There is a lower power version that you just need car licence and L plates.
It’s 100kg (with removable battery), 40mph and 50 mile range….not huge but enough for us to get to places from pitch then back again. Just shy of £3k OTR.I have full motorbike licence, but thought that it did not cover these. Has the law changed to allow electric bikes now?
Would be interested to know weight, power, range and cost.
