- Feb 24, 2018
- 681
- 1,359
Looks good everyone settling in nicely
It's lovely Tam, really homely. I still think this one is a keeperFinally a bit tidier. , all lights have now been changed to led bar the doglight in the bathroom as I can't figure out how it comes apart. Added new led strip lights around the cab area cupboards and a brighter led light under the centre cupboard too as there were no lights in the cab area at all. TV is now mounted in the cupboard above fridge. Can't plug it in yet as I'm waiting for power plugs in post. Fitted USB charge points in the old TV cupboard above the cab and a pair in the bedroom . New Teddy bear fleece throw for the sofa ( actually a single duvet cover which works perfectly credit to Just smiffy for the idea ) new non slip floor matts and all new doggy beds ... feels more homely now .
I'll put night mode pics with lights on later.
Still need to sort that skylight surround , once I've figured out how to wire the motor to a rocker switch to open it as the remote control electrics are knackered View attachment 945902View attachment 945903View attachment 945904View attachment 945905View attachment 945906View attachment 945907View attachment 945908View attachment 945909View attachment 945910
No it's just one big cushion on the bottom 3 cushions on the top the whole lot fits inside the duvet cover. Works perfectLooking good inside Tam.
Is the base of your “sofa” fixed down, if so how does the Duvet cover cope with that?
Also I found this company a while back, not ordered anything yet, but they sound good.
They have waterproof throws too.
Where do I find one of those?You need a double pole changeover switch (DPCO) with centre off. It will have 6 terminals. Wire two end ones to 12v / 0v. Then wire those two terminals to the two at the other end with a cross. (Top left to bottom right and vice versa). Take the centre pair to the fan motor.
Can't beat a bit of velcro now and again Just smiffy , but not on underwear!The throws were sliding off the leather sofa so a single duvet cover they just go round and round…
Although I think there maybe some Velcro somewhere..![]()
The velcro is waiting for you and your sewing skills lolThe throws were sliding off the leather sofa so a single duvet cover they just go round and round…
Do you have a link for your warm led stripWhere do I find one of those?
Got a link ?
SureDo you have a link for your warm led strip![]()
TaDPCO switch.
Yes she eats too fast ....but she's getting better. I was hand feeding her up till a few weeks ago . Now she's got the slow feeding bowl. Still tries to gulp it downBlu bolts her food?
Hopefully that slows her down a bit!
She obviously doesn’t want to lose her spot on the sofa!
It's hard to tell Michelle, at the minute I've to keep it on constant hook up as it will cut off if I don't. I don't think they're holding charge for long under use .Tam, Any life left in the old batteries? Are they still useable or not worst keeping?
might still be ok for the short time I need to use them. I'll pick them up when you have your Lithium so I can see your luxury living standard!It's hard to tell Michelle, at the minute I've to keep it on constant hook up as it will cut off if I don't. I don't think they're holding charge for long under use .
Has the motor frame got a negTa
Might need a lesson in how to wire that up .
I've a pos/neg cable coming in . And then 2 pos wires from motor but no neg .
No neg on the actual motor .. 2 lives from motor originally went in to a circuit board along with rain sensor wires etc etc. There's a pos and neg supply from the van wiring but that's it. I want to bypass that circuit board entirely and just run the motor from a switchHas the motor frame got a neg
Ah OK that makes sense , I figured one wire was for one direction and the other wire for the other direction.Use an electric window switch
You don’t have two live wires to the motor, just two wires. IE supply 12VDC on Red and 0VDC on Blue wire, vent opens
Reverse the wires, roof closes
The defunct circuit board would have swapped polarity
