- Mar 6, 2020
- 116
- 80
- Adria matrix
- 13 years
What a predicament Manufacturers/converters of motorhomes ( and caravans ), designers of 12v electrical systems and manufactures/suppliers of leisure batteries ( not to mention cowboy MH dealers ) have got us into.
With complete disregard ranging from inadequate cabling to a mishmash of charging technologies and battery types and not having made any real effort to ensure a proper working concept to power our second homes.
My 'desire' to incorporate a B2B system into my new Adria Motorhome stemmed from having the factory fitted AGM battery fail during a tour round Greece last year at just 13months old. After investigation ( with help of Leoch technicians who were genuinely concerned this battery had failed so early in its life ) I/we found that the battery ( A Leoch 100ah AGM ) was actually a UPS model not designed for cyclic use at all, and Adria had bought and installed a batch of these ?
God knows how many Adria owners are driving round in their vans with a battery thats going to fail first time they try wild camping without a EHU hookup !. Mine and many others are/was doomed to fail after a few charge/discharge cycles from day one !.
( Any Adria owners with AGM battery fitted check model number - if its Model Leoch LPL-12-100 then its the wrong type of battery and will fail if used for charge/discharge use - this battery is used for backup in computer centres and in equipment that must not stop if the mains power supply fails and is capable of sitting there for many years on trickle charge waiting for time its really needed but if used in a cyclic system like a motorhome, caravan, boat, etc it quickly will fail if used in a repeated charge then discharge use. Mine was fitted in early 2018 and I am aware that Adria was fitting a different, NDS type battery by Dec 2019. Brownhills Motorhomes did check their stock motorhomes in October last year and said they all had this same battery fitted and also that a check of recently sold Adria's also had the same battery as mine, so how could it be a problem ??. They just advised me to contact Adria )
Looking further into why mine failed ( apart from charging and discharging it ) I found that the solar (shaudt ) controller fitted by the MH dealer ( Brown..., Newark ) was only suitable for normal lead acid batteries not AGM, the alternator could not fully charge the battery at 14.4 volts and the Nordelctronnica power supply was set for a Gel battery 14.2v regime ( as the other available regime was lead-acid ) so also could not charge the AGM to its required voltage of 14.7v minimum.
So, after changing the AGM ups battery for a larger 160ah proper 1500cycle advanced lead carbon AGM, the shaudt solar PWM regulator for a Votronic MPPT regulator with 'agm2' setting, switching the power supply from 'Gel' to lead setting (14.7v) despite adria's insistance that the gel setting was more appropreate for the fitted battery ? ,that just left the problem of how to incorporate a B2B into the existing Nordelectonica as the split charge system within was sadly lacking in capability to charge this new AGM.
The story continues with my earlier post putting out feelers for the suggested wiring diagram in which a NC relay across the B2B in and out +ve's and wired in series with the split charge relay ( which I cannot get access to remove ) sounds like a solution to the loss of cab battery charging and voltage measurement when I wire the B2B using just votronics installation instructions.
Sorry for the length of this tale but there may be something useful to someone in it
