- Oct 25, 2022
- 127
- 299
- Adria Matrix 670SL
- Since 2018
I don't know enough about smart alternators to tell you if there is some kind of fault and maybe it shouldn't be doing this. But if it is working as intended, then there is a solution.
You want the B2B to come on if the engine is running AND the voltage is above a threshold, say 13.5V. The B2B starts working as soon as it gets a signal on the D+ input. So, you could put a relay in the D+ signal path, with the coil triggered by a voltage-sensitive relay (VSR) with a suitable threshold voltage. The VSR should be connected to the starter battery, so it senses the alternator output voltage.
As the Alternator voltage rises, the VSR switches on the D+ signal, activating the B2B if the engine is running. when the alternator voltage falls, the VSR switches off the D+ signal, so the B2B is inactivated.
If for some reason (eg solar power) the starter battery voltage rises when the engine isn't running, the VSR will trigger, but there is no D+ signal so the B2B won't be activated.
The VSR and the other standard relay would be switching a coil and the D+ signal, so they can both be low power, they don't have to be high power types.
Thanks for all the suggestions, esp around controlling the D+. Probably need to investigate what’s going on with the alternator output (especially the delay until it’s revved up) to see if it’s smart or if there’s a fault there. Also to check out whether we have a proper D+ or just an ignition live. Then we can manage where we go from there.I think you are right, and I think that smart alternator isn't working properly. If the B2B turns on, the alternator should provide power to it, even if it is at a low voltage. But the Ava the Adria says it doesn't, and the B2B takes power from the starter battery, causing it to discharge. The arrangement I described,with the VSR on the D+, would stop that happening, but as you say it doesn't solve the underlying problem.
