- Feb 24, 2013
- 13,737
- 103,763
- Hymer S800
- not long enough
Looks identical to the TecTowerin our first Hymer we bought new in 2008.
Did yours have electronic and mechanical locks?
Ive had a quick look through the thread david.. im not familiar with the fridge models you may be able to get as a replacement... but for what its worth id be looking to keep the oven grill you have.. it should be possible to remove the present controls from the panel for your oven and re mount them in new panel. If you can find a fridge that gives a little room for that... the only issue is the way the fridge and oven are attached or fitted in.. so as long as the fridge can be removed as a unit..Then we still have the oven to deal which will also needs to be replaced, as mentioned above it is controlled from the failed fridge,
Our Tech tower has a Smev oven on the top with its own rotary Control/Igniter combined in the bottom right hand corner. It looks like the electrics are shared at the back to provide the spark.
I have been out to the van and ours has a curved front. The oven clearly matches the Dometic fridge freezer but the oven is most certainly a separate unit - I can see light between the top of the freezer and the bottom of the oven. The oven front is badged
https://www.ebay.co.uk/itm/292706433203?ViewItem=&item=292706433203
have found this, seems slight expensive, but has anybody got this exact model?
Is the drawer on the bottom a fridge or freezer section?
You can. However I'm undecided as to whether I'll keep it for the next owner (very unlikely) or whether I can use it's outer curved door as part of the microwave installation. Either way I'll let you know as soon as my fridge / freezer is repaired.That sounds like excellent timing can we please have first dibs on the oven unless it is already spoken for
Sounds pretty much like ours, just newer, there is one obvious screw on bottom of oven into top of fridge where the door closes, we presume there are other fixings
But the gap worries me on mine, that gap goes through to the vented area at the back where the fridge gas burner is, I would have thought this area should be sealed, ours isn't either, we get quite a draught through the gap between oven and freezer and over top of oven if the wind is in the wrong direction
If you mean the single rotary control for the oven then Yes. It is. And it is identical to the one in @Abacist photos.Just to be sure I don’t end up with the same as ours, your oven controls are all on the oven ?
No oven may limit potential buyers in the futureUnusually for me, I have done a little more checking before buying
the RMF8505 is actually as tall as our complete tec tower
now weighing up whether the extra fridge space is more valuable to us than the rarely used oven
would a new buyer be put off by no oven? not that we think we will sell soon (too much invested in it )
A major plus would be, simpler fit, no oven to source
Mechanical slide in the middle, use to fly open if you took roundabouts too fast.Did yours have electronic and mechanical locks?
That version is nothing like the RMDT8505 which has the oven above, I think @Abacist one is the RMDT 8505 which is what we have had in our last 2 vans.the RMF8505 is actually as tall as our complete tec towe
Easily solved fit a roof vent.Thinkbthis was mentioned eaelier but is the size and type of fridge not also dictated by the vents on the side of the van, bottom one could be fine but the upper vent might be too low if you were to get a taller fridge
That's the sort of thing tuggers do you must be getting soft.this could just be our answer, we already use the cylinders for awning heaters
The fridge vent is a big oblong unit, probably be able to fit over the hole for the oven one.interestingly we will have an unused roof vent from the oven
I think the oven one will be far too small.cant see it really making any difference what shape the vent cover is, my existing mushroom one for the oven will do well I reckon
at least until the fridge doesn't work well, then I might change it
