The programme "love thy neighbour " used to really crack me up![]()
There were lots of great programmes we will never see again, but I haven't grown up with any prejudices because of them.
I bought closed cell foam insulation and sound proofing Matt and fitted that in place of the polystyrene. And I managed to salvage the original black cloth ( unfortunately in two pieces ) and fitted that back in ..Tam, what did you do with the rear cupboards or are they still a WIP?
Cant use those names on tv now but can F it blind,,strange world,,BUSBY.It's odd when you think about it, us older folk (I'm a bit older than you Tam, but still a spring chicken on here) have to adapt to the views of the modern day snowflakes and accept the fact we'll never see any reruns of "It aint alf hot mum" "Rising damp" etc shouldn't they be accepting what was the norm for us, after all we won't be around for ever and then it's their time! They can watch politically correct tv and call colours whatever they like.
This soddin van is definitely out to drive me insane , just took it to kirkcaldy to fill up with gas ....I've no wipers and no heater
Checked fuses and they are ok ....nothing wrong with either of these things when I parked it up last month
And why on earth does it have 4 bloody fuse boxes ????
So I don't know if theres maybe a master fuse above the other fuses or what but seems unlikely to have a wiper motor and heater blower both pack in at the same time with no prior warning
Just made it back to mums in time before the rain came on or that would have been fun
Aye well its character is getting right on my mammary glandsIt's called character...
You have a van with "character"
It's the blood pressure I'm worried aboutYeah Tam, but think of all those new skills you have learnt!!!![]()
The norm would presumably to poke fun at minorities who were already marginalised, who had fond memories of seeing signs on businesses stating "No blacks, no Irish, no dogs"? It is impossible to walk in their shoes or to see the world from their point of view. It wasn't (and isn't) the norm amongst my friends. I wasn't comfortable with it then or the racist views of my parents and I'm happy to align myself with the tolerance in evidence now. Being PC has nothing to do with it.It's odd when you think about it, us older folk (I'm a bit older than you Tam, but still a spring chicken on here) have to adapt to the views of the modern day snowflakes and accept the fact we'll never see any reruns of "It aint alf hot mum" "Rising damp" etc shouldn't they be accepting what was the norm for us, after all we won't be around for ever and then it's their time! They can watch politically correct tv and call colours whatever they like.
Nothing at all from the heater , no wipers, no washers.& if it isn't the fuse then it could well be the earth for the wipers. Fiat earth everything seperately. The heater . has it any speeds at all? Could be the infamous resistor. Either needs a new one , if it runs flat out but nothing else or puttingb the rheostat in the freezer to get it to reset.
From what I can see in the over complicated manual the fuse for heater is in the box nearest Lh door but the wiper one is a maxi fuse in the big fuse box under the bonnet. Checked both of them and they looked okay...but ran out of time today as had to go to work so I'll have another look at it tomorrowI think it’s a fuse Tam.
After fitting a dash cam I lost wipers and heater fan. After much fiddling about I read the manual (RTFM) and found one fuse covered them both.
On our Ducato it was in the fuse box under the dash (close to the door on our LHD)
and I think it was the top left........but could be wrong. It just needed a hefty shove in as it hadn't been pushed fully home.
Richard.
I'm thinking I may have blown one of these when I connected the fog lamps.Can't see it being anything you have done as the wipers & heater are fed from a switched ignition source, if it was something you had done a lot more things wouldn't be working.
Might just be coincidence that you have 2 faults at the same time. The heater resister is a common fault, Hymer fit a Schaudt relay box under the bonnet to control the wipers on their A class vans, worth checking if you are getting a feed to the relay box.
I've not but I'll check that tooHave you checked whre stalk plugs int harness in case you have pulled plug slightly ? It wont be those megafuses .
It's going to be a single fuse that looks after the controls that operate the various things that aren't working. Try F31 & F38.
Yes I'm inclined to think it's one fuse causing the issues too , it seems a very big coincidence for the heater washers and wipers to all suddenly stop working when no issues with them beforeBit of light reading for you Tam, could well be of some use (F71 could be your culprit which I think is the middle of the smaller fuses on your pic)
Definitely the fuse that Richard has described. I had the same symptoms and same fix recently ie. Blown fuse in UK near side dashboard fuse box.I think it’s a fuse Tam.
Richard.
I've checked all fuses in the two fuse boxes inside van either side of dash and they are okDefinitely the fuse that Richard has described. I had the same symptoms and same fix recently ie. Blown fuse in UK near side dashboard fuse box.
I did the same as you Tam and convinced myself there was something wrong in the maxi-fuse box under the bonnet, but it wasn't...
with a meter or by eye? often they look ok but aren't.I had one recentlyI've checked all fuses in the two fuse boxes inside van either side of dash and they are ok
