Northernraider
- Jul 30, 2017
- 34,938
- 260,832
- N&B Flair 8000ib
- AirOn and off since 95
The citadel and castle of braganca
Yes I've noticed that too . Everytime something's happened, alternator , brakes , tyres ,skylight ..always a bloody Friday or Saturday..Hard luck Tam, but it confirms my theory- these things always happen at weekends!![]()
But I'm in the middle of nowhere now so I have to find a garage that can fit a motorhome and hopefully it's just needing it's service done.
I'm hoping it isn't dirty diesel as I only filled up at Zamora.
But it certainly seems like it has kangaroo fuel![]()
I'm in Spain again. Just pulled in to a parking spot at puebla de sanabria. There's a garage near here opens Monday morning so I think I'll have to just stay here at the minute as it's really running rough. And struggling on the hills. Wouldn't be so bad if my code reader would tell me what's flagging up but still saying no codes stored.
I don't have any white smoke...or any smoke to be honest, just like a misfire and splutttering![]()
Dodgy Diesel
Hi... Thought I would pass on this stressful moment. With the knowledge of no services after Granada until you get to the coast I decided to get topped up with diesel even though we had half a tank. After filling up I started to notice the occasional spurt on the accelerator. I thought it...www.motorhomefun.co.uk
It hasn't gone In to limp mode in fact if stationary it splutters when idling but if you rev it then it seems to be okay at high revs . Don't want to take it to fiat though. Most garages should have a code reader so I will see what this local one says on Monday.We had a warning light, and limp mode come on at Braganca, luckily we were still under fiat warranty, the nearest Fiat garage was in Amarante the garage name is Mcoutinho, if any use to you
Nothing on dash except the emlIs there any odd stuff going on the dash, indicators working and so on, just wondered if it's a dodgy earth. ? Bob.
Just seen the latest might be worth draining the fuel filter.
Yeah it's not a bad spot I'll survive lolSo if you are in a pleasant enough parking spot just put the motor out of your mind and enjoy a nice peaceful weekend with the dogs exploring your surroundings.
If you really want to focus on something else, get the bike trailer out,hook up,put both dogs in it plus survival rations and head off into the wide blue yonder.....
The pleasure or the pain will take your mind off Toby![]()
Don't rush to get rid of it, if ultimately you buy yourself a plot that you live on in Toby it could come in really useful.Yeah it's not a bad spot I'll survive lol
Haven't used the bike or trailer much this year we prefer just to walk. Something else I might just get rid of when I'm home.
Aye that was my first thought because I was drawing sand up through the air vents at one point but air filter doesn't look too bad to be honest.Check air filter too as your in a dusty environment and have been for some time,...
The trailer I may keep but the bike if I was going to keep one I think I would change it again to a slightly larger one and one without disc brakesDon't rush to get rid of it, if ultimately you buy yourself a plot that you live on in Toby it could come in really useful.
If you do that and find you haven't used it after 12 months then perhaps you could think of selling it .
Yeah I'll just be happier once it's been looked and and found to be nothing serious.I can't help with your problems but if you're going to breakdown anywhere it couldn't be a nicer spot.
Hoping you get sorted Monday![]()
Got to be a poor connection or as it's fed via the EBL could be relay or burnt PCB.So the heating issue.
When I switched it on this morning I kept the voltage meter on the main live and neg feed to the heater.
To start with it was 12.5v
As the heater fan started to get up to speed that slowly dropped from 12.5 all the way down to 10.4v that's when the red light kicks in ... now normally it also cuts of when red light comes on but somehow it's not done that yet....but currently reading 10.3v at heater and 12.2v on control panel View attachment 337218View attachment 337219
So any ideas?
P.s also checked at actual batteries and with heater still on full whack they are both reading. 12.2v each so correspond with panel
Yeah I'm suspecting my ebl has a few issue. : (Got to be a poor connection or as it's fed via the EBL could be relay or burnt PCB.
Run a pair of new cables direct to the batteries with a 10 amp fuse in line at the battery end. That's how the wire them on newer vans. That should get you out of trouble for now.
Good luck with the engine.
in a way thats good news as you suspect the ebl has problems anyway at least its not ebl and heater.how thick is the 2core you have if its any distance from boiler to batteries it might need heavier cable.Yeah I'm suspecting my ebl has a few issue. : (
I think I have some 2 core cable in the garage so can run wire from battery to heater no probs just need a fuse holder
Just one problem after another lol.
I’ve of people having good service from Schaudt but you have to send to Germany or on your return have a trip to Somerset to these people.
Schaudt Elektroblock EBL99
www.apuljackengineering.co.uk
