golly
- Aug 16, 2009
- 2,120
- 80,433
- HYMERCAR PVC
- since August 2009
Tam,Toby,and Two on Tour(TTTT)
Yeah everyone I think of is too long tooIt’s tricky to think of a catchy one now that there are 4 of you!
I can only come up with long ones
What Tam (Jade, Milo and Toby) did next
I think it woukd be easier to start a new one this ones a bit long nowDo you have to start a new thread or could you just re-name this one? It would be a pity to lose sight of all that has happened since you embarked on your European adventure. I’m a but of a sentimentalist and love being able to re-visit Past memorable places and events.
Aberdeen is a very dull looking city , I've not seen a great deal of it to be fair I just have a couple of friends who live up there and want a catch up before I head off again.I'll be kinda crossing paths with you this weekend. Gotta fly back to Aberdeen for a hospital appointment. Must admit I do miss the cold, dull, grey city.
You know everytime I see your avatar pic I think your van has a slide out. ..then I realise it's just the doors openTam 2. Just when you thought it was safe to go back across the water.
(Sorry).
+1What about
Tam and crew, part two?
It's inside your fresh water tank ...You should have a small lift out flap on the floor behind cab seatsI will have to admit to not knowing exactly where my pump is! I can hear it, so know approximately where it is, but when I look where it might be (under the left rear seat or under the wardrobe) it doesn’t seem to be there.
Blue Positive, Brown negative (standard Motorhome wiring).So could someone check theirs for me please and tell me which colour wires you have connected to the brown and blue pump wires
That photo looks like the wiring is crossed over.Blue Positive, Brown negative (standard Motorhome wiring).![]()
This is ours- Shrimp/Manic’a pump wires.
Unfortunately not as simple on mine. The 3 wires from the van are green, pink and purple they all have hymer 654 pumpe written on the wires so they are original ...but none are identified as + - etc . At the minute the purple is a loop so I reckon that's earth.the pink and green I can connect either way to the brown and blue wires from the pump and it works and sounds much the same either way.Blue Positive, Brown negative (standard Motorhome wiring).![]()
But jade is a girlTam, 4 men on the job?!?!
Pink is positive and Green negative (strange Hymer wiring.)Unfortunately not as simple on mine. The 3 wires from the van are green, pink and purple they all have hymer 654 pumpe written on the wires so they are original ...but none are identified as + - etc . At the minute the purple is a loop so I reckon that's earth.the pink and green I can connect either way to the brown and blue wires from the pump and it works and sounds much the same either way.
But someone had told me before that the wrong way means it won't pump as good.
It seems to work either way that's why I was asking which goes to which.That photo looks like the wiring is crossed over.
So, is the pump sucking instead of blowing??
Richard.
Ok cool will doPink is positive and Green negative (strange Hymer wiring.)
So connect Blue to pink & brown to green. Something every Hymer owner should know.
The purple one is unique to you.![]()
