Sudden Voltage Drop when I turn the inverter on (3 Viewers)
Huffum
Feb 15, 2023
23
63
Barry Island, Barry, UK
Autohomes Wayfarer
I'm a newbie
Found the culprit - blown fuse coming off the +ve terminal of the battery.
I was sure I checked the first time around but ended up going back around again today to check all fuses and connections again.
Apr 26, 2015
3,281
7,943
Ottershaw
Hymer S820
First motorhome May 2021
Glad to hear it was something simple in the end. I only have a small inverter but I never turn it on with a load plugged into it, i always turn the inverter on before plugging anything in and turning it on.
Dec 2, 2019
3,877
8,563
Amersham
van conversion
Since 2019
That fuse looks a bit bent. Was it in a holder or loose? Also when you tighten the nut, it helps to have a spring washer under the nut, when the nut spins does not bite on the fuse and try to twist it. They are fragile and is a no no without a holder.
Huffum
Feb 15, 2023
23
63
Autohomes Wayfarer
I'm a newbie
It was in a holder. But it wasn't done up tightly.
I thought it looked a bit bent.
Good idea on the washer - I'll get that sorted.
We had the electrics installed by a company, so I'm still learning as I go with it.
Appreciate the tips!
