Glad to hear it was something simple in the end. I only have a small inverter but I never turn it on with a load plugged into it, i always turn the inverter on before plugging anything in and turning it on.Found the culprit - blown fuse coming off the +ve terminal of the battery.
I was sure I checked the first time around but ended up going back around again today to check all fuses and connections again.
That fuse looks a bit bent. Was it in a holder or loose? Also when you tighten the nut, it helps to have a spring washer under the nut, when the nut spins does not bite on the fuse and try to twist it. They are fragile and is a no no without a holder.Found the culprit - blown fuse coming off the +ve terminal of the battery.
It was in a holder. But it wasn't done up tightly.That fuse looks a bit bent. Was it in a holder or loose? Also when you tighten the nut, it helps to have a spring washer under the nut, when the nut spins does not bite on the fuse and try to twist it. They are fragile and is a no no without a holder.
