Puddleduck
- Jan 15, 2014
- 13,233
- 52,743
- Without at present
- On and off for many years.
The smell could be a failed or failing earth strap causing arcing. Similar with a loose connection, which would most likely be on battery, or starter motor.
I’d also a remove the hab electrical connection to the starter battery in case the hab electrics are constantly drawing power from your starter battery.
With a jump lead, have you tried connecting the negative terminal of the starter battery directly to the engine block, (any big lump of metal attached to the engine) this will bypass a bad earth connection.
Why not clip the NOCO under the bonnet, leave for 1 min then start it.We do carry both jump leads and the NOCO, bought extra long leads thinking I could jump from leisure batteries to jump connections under bonnetnope leisure batts are too close to cabinet roof to get to terminals without removing
No need for jump leads.
Yep I always used to isolate them as well along with the solar panels which will also back feed.In my experience you can not be sure that the hab battery won’t back feed to the vans system.
Exactly what I do on my underseat starter battery every time. That's after isolating all the above, + I then cable tie the rubber glove on each.. Due to this I would, disconnect the negative terminal on the starter battery, then the live terminal, but then immediately protect the live terminal from shorting. Such as putting it into a Marigold washing up glove, or similar.
I guess the NOCO does need some input from the battery, so if that is low or badly earthed the Noco on its own may struggle?I did put the NOCO directly on the battery and didn’t notice but will look again tomorrow
I hope so , went out to mine yesterday and nothing, put on hookup went out today and nothingIsn't there an old school of thought that says whack a starter motor with a hammer if it sticks?
I may be out of date, but on older alternators D+ was often supplied by a secondary diode trio separate from the main pack/rectifier, so it is possible that the D+ is giving 14, while the main pack is not.I think it must have given 14V to activate the D+ relay as the AES fridge had definitely moved to 12V
Where is the smell. Inside or outside?got whiff of burning again
Definitely confirmed as coming from the connection to the starter motor , I turned key while man underneath![]()
At least new starter is an easy job
Talk to the owner/staff of the campsite you are on, they may have a person who does their vehicle/machinery repairs
If I was there I’d stab a starter in for you.
If you want to guarantee you have the correct part. Talk to coastal motorhomes. They will select the part via your vin no.We are looking at options to get a starter motor shipped to us to simplify the job maybe, presuming I buy the right one![]()
