Wow great work that nice to see something different
Any small wood working shop will do it.
Otherwise you can buy a kity 636 and sell it to me!
They're accessed from the outside on the Sprinter (makes life so much easier).As a ducato based van owner, I dont know about the sprinters but how do you access the rear light clusters to change indicator / brake bulbs? Are they externally accessed or are you having to leave a way through the panels?
thats great - i can see how that will save you a lot of work making parts easily removableThey're accessed from the outside on the Sprinter (makes life so much easier).
Just open the rear doors and the screws are above/below the lights![]()
Using a 230v domestic one Tam.
I've been running one in my own van for 3 or so years and really like it. Keeps a better temperature and silent, not to mention the cost. With mine, it's power consumption is so low that even with the inverter overhead it still uses less than a standard 12v compressor model. After initially installing with a small Victron inverter, I swapped over to a larger model as figured I may as well have 230v on tap.
This van's electrics work the same as my own, in that there will be 230v always on via an inverter.
When I did the relay with bathroom across the rear I simply drilled and countersunk self tapped the rear lights so I could change the bulbs from outsideAs a ducato based van owner, I dont know about the sprinters but how do you access the rear light clusters to change indicator / brake bulbs? Are they externally accessed or are you having to leave a way through the panels?
Yep, this one is Bosch Rexroth 2020 (20mm x 20mm).Looks great. Is that the extruded , quick build frame ? Ive seen it used in plenty of factories etc for building guarding around fixtures etc.
Lovely job
Nice but not my cuppa tea!!Quick one showing the board all fitted:
This was before any filling etc which is now done. Being primer'd now.
I don't think I've mentioned how I like to build furniture before?
Here's the frame for one of the units sat in place:
The bottom section houses the LiFePO4 battery, then 3 x deep drawers above, then a double door cupboard. This is a really strong and light method of cabinet making that keeps everything nice and square.
I like to hide all the fittings when building these as I think it looks neater. Although you wouldn't see it anyway unless opening a drawer or cupboard. The small holes are where the fixings are, these are filled with buffers to aid the soft-closing drawers.
There's quite a system going into this (it's a fulltimers van who works online).What sort of Lithium/solar are you thinking about Wissel I assume the fridge is just 240v
Why are you using 3 MPPTs?
Just like to add my total admiration of Wissel on this project. To follow someone so on top of their game, with skills I could only dream of having, is a privilege. Really looking forward to seeing the finished van. Total respect!![]()
Thanks. That's a good idea.As the panels are high voltage, there's no real benefit to fitting the panels in series. So we went with separate MPPT's for each panel to avoid any issues with shading.
TBH there's not much difference in cost between using 3 x smaller MPPT's or 1 much larger one, plus if one ever did throw a wobbly, the other two wouldn't be effected.
A little off topic, but my god one of these would make my life easier:
No more templating, could program a panel once and rattle the same off at any point, need a perfect circle - done in a minute.
Not cheap at £3300, but made by the sister company of Festool, so likely great quality.
If I didn't have a Vario to build....
One of these sold on ukworkshop for £1k iirc....You know you need it for the Vavrio build. Looks a great big boy's toy, that you must have in your arsenal![]()
how does a laser work in a van when i built ours i only used a level as a straight edge everything was measured from the floor
Hi David don't worry you won't need circle's![]()
