Solar Power Outage due to Dust (1 Viewer)
Mar 7, 2023
10
42
Iveco Daily 70C17
This is an interesting one that may help other MH users in the same situation. Over the last 4 days I have dawdled down from Bilbao to Tarifa, ready to get the ferry to Morocco tomorrow morning. I noticed today that I was getting no charge from the solar panels (3 x 200W Renogy) even though the sun is very bright and hot. Went into panic mode - no chance of expert help in Morocco - I'm doomed, so had a glass of very cold white wine to think about it.
I managed to get up to a point above the van to study the roof with binoculars - no sign of physical damage to the panels or wiring, but the panels were very dusty (having been cleaned before leaving home last week). Another clue came from the Victron solar controller app, which showed the solar power falling from 360Wh on Saturday, at a max voltage of 23.29V to 0Wh at max voltage of 13.93V over the last two days - no gradual reduction, just a step off. I think the supply voltage (13.9V in this case) has to exceed the system voltage by 5-6V to produce any power, so this at least confirmed the system was undamaged, but not achieving a high enough voltage to produce power.
Having borrowed a ladder from the campsite owner, and mopped down the panels to get rid of the dust (which was quite stubborn), I am now getting power again, at 21.49V - its 8:00 pm local time and the sun is on the way to setting. Smiles all round and more white wine consumed. I am guessing that the plume of Saharan dust that is passing over Spain and France was to blame - it is quite thick and apparently quite sticky.
So the moral is - don't panic like I did, drink some wine and wash the roof, in that order. Then drink more wine.
Happy trails!
Mar 7, 2022
151
429
Hobby Optima T70 HQ
Thanks for that. I'm just fitting new solar panels. 2 × 175w.
Was thinking of putting Rainex on them to help keep them clean. Has anyone done this? Of course might not be good with dust.
Dec 24, 2014
9,301
47,983
Hurstpierpoint. Mid Sussex.
Compass Navigator
Rainex doesn't last very long in my experience and it's proper function is to make water form beads.
(y)
It only works O.K. on my m/cycle visor as the rushing air drives off the droplets.
It's especially important for me as I ride one-handed so can't take my good (left) hand off the 'bars to wipe the visor (or scratch my nose or eject a bee from my full-face helmet :confused:)
18,057
48,264
Happy trails!
I'm surprised that a light dusting would totally stop the panels working. I've often had my panels covered in dust and they still worked although obviously not as well as a clean panel.
Are you sure the lack of charging wasn't down to the batteries already being fully charged? You might have 600W of panels but the controller won't allow them off the leash if there is no need.
tonka
10,863
21,597
Cannock, Staffs
A class Burstner 800
Since 2000
Somewhere on here is a thread ref this. I recall reading in the past. The outcome was not a good idea, leave as they are and just a wash over now and then..
Aug 18, 2014
23,940
135,377
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Depends on the area also.Here ,where I live , it is normal to clean the panels twice per week. The dust is extremely bad without any need for saharan. Fixed house panels around the area suffer the same problem.Some are extremely bad. The commercial centre up the road to me has three huge banks of panels that have never been cleaned,apart from rain & we haven't seen any of that for a couple of years,& the loss of power must be huge?
Or drive faster so it doesn't get chance to settle. :giggle:
doesn't work.
I am always pleased when In the Uk that I never have to clean my panels.
May 7, 2017
1,974
2,296
Suffolk
2017 Chausson 718XLB 180
20 years
I bought a extendable pole with a fitment on it with a cleaning pad affixed about 9 inches from the pad I can adjust the angle so it is about 90% to the pole, I then soak it in water and by using feel (when the pad drops over the other side of the panel)wash the panels and hope that I have cleaned them , never lost charging .
Apr 12, 2012
1,700
6,398
N/E Lincs
Autosleeper Rienza
as above
When I did the annual roof wash this spring the panel was green with mold more than so than I remember. I can’t check the output but the batteries stayed charged over the winter during our of grid stays and stood on the drive.
Having an older motorhome with a ladder up the back I have no excuse for not keeping it clean. Maybe if I could monitor the output I would try to keep it clean.
Jan 19, 2014
9,427
24,888
Derbyshire
Elddis Accordo 105
since 2014
I'm surprised dust would stop the charging completely 🤔
I think with 600w your controller may have just ended the charging anyway.
Feb 16, 2020
2,343
3,202
KT15.
Sunlight. T66. 2019.
Absolute beginners.
Happy trails!
Will this remedy work with other alcoholic beverages, I don't like wine? :unsure:
Mike
Sep 1, 2018
2,004
6,735
Strathaven
Pilote G741
Since 2018
Pulled my MoHo out the shed today, after following this thread I thought I’d do a experiment , 2 x 100 watt panels , i was getting 7.2amp , then I cleaned the dust off the panels ( wasn’t overly bad ) went up to 7.4amp , so made a slight improvement
Sep 17, 2017
5,579
10,431
Birmingham, UK
A-Class
If solar panels were that susceptible to dirt buildup, residential panels that never get cleaned would be useless.
I'm also betting that between the driving and the good early sun, the batteries are charged by 10am. So you're never seeing a full peak load.
Oct 30, 2016
1,466
2,890
Colchester
Le voyageur 8.5
On 3rd van so not a total newbie....
Residential panels tend to be at an angle so tend to be self cleaning, but I do agree with you, the effect of dust/dirt is over estimated, we were in Spain last November and were covered in sand, I thought I would clean them and we would get more power, but it was barely noticeable.
53,961
152,014
I think you have a problem with your panels a coating of dirt & dust will reduce the output but only by 10 or 20% it won't kill it.
I've had my panels covered in Sahara sand and it's only reduced the output by a couple of amps. I carry a telescopic ladder so I can clean them.
