Debs
Post numbers are shown on every post. Can you see this is post #2
Thanks never thought to try thatWhen we make a site responsive to all devices its not just a matter of shrinking it, that would not work, stuff has to be omitted. But in landscape mode you will see post numbers
They don't show if you're using a phone to view.
Yes they do. In landcsape, unless your using an old nokia 1011
I do when I want to see the info that you can't see in portrait.Landscape? Pfft. Who looks in landscape?
Have got screen rotation turned off?I must have a Nokia 1011
not that I use my phone for much, apart from calls, but it doesn't seem to do landscape
It is a Nokia something because it says Nokia above the screen
I always use my phone in landscape mode,easier for my old eyes, bigger text. Bigger pictures.
David, just try it, the length of time it took to type your post you could have tried it & found out either waygreat question, I am more than slightly impressed that I found a way into the settings menu, but now still confused
bit of double negative here
heading - screen rotation
rotation lock - off
not really sure whether that means it will rotate or not, sounds like it should
