Shower head leaking
kelv
leicester
Carthago 145
Anybody had a small leak from the shower tap no idea how to fix leaking from white thread when unscrewed from shower head as per pics
Having a nightmare away in Spain and can not access to remove complete tap
Usually a screw under the red/blue temp marker, pop them out and probably a screw underneath.
If in uk Screwfix do cheap cartridges , not sure if there’s an equivalent in Spain.
Finally sorted getting access by removing panel at the side of the shower see pics should be an easy job getting tap of now famous last words
Hope this helps anybody else with the same bathroom layout who has the same problem.
I don’t think you need access to the rear unless you going to replace the whole unit, to replace the cartridge that would all be done from the front.
But if removing the whole assembly the the red and blue spigots will be held in place with a small pin, that needs pushing out.
The black pin in the centre
We had a leak in our shower. On return to UK replaced the cartridge with one from Screwfix for about £8. It was the 35mm one. Took about five minutes to get the old one off. Same as on kitchen and bathroom mixer taps.
Tried to get the nut of the front once handle was removed to get at the cartridge just will not budge so that’s why I am taking the tap off and I will replace the whole tap with a easier one to maintain
If the nut is nylon , I’ve had a problem undoing the nut because a box spanner just slips.
My method is to drill a couple of holes in the nut flange and use circlip pliers or long nose pliers to undo the nut (red) and holes (green)
Good idea I am in Spain so I am going to cap the shower pipes off and give it a go when I get home
Will have a lot more tools and kit.
staying on sites so shower will not be missed
I found this when doing the leaking kitchen tap. Sprayed the flimsy chrome collar which needs removing to get access to the nut and the nut itself with a release agent and left it while I had a cuppa. Thereafter, the collar came off and removing the nut with a shifting spanner was easy.
There should be a rubber washer inside the nut on the hose. Try replacing or cleaning it.
Had the same problem removed the cartridge soaked it in wine vinegar this removes any salts replaced job done works fine
Did you have a problem removing the black plastic nut
Anyone have any idea where I can find a replacement shower tap with the same fixings
