- Feb 2, 2015
- 2,407
- 7,514
- Nowt!
- Learning to appreciate what time we have left
That could be a while then!! ....................LolWill do. Just have to reach final agreement with the co-pilot!
No brainer, first option Mrs funflair ticked on the new van.That could be a while then!! ....................Lol
The VB system as you quite rightly say ..Cannot compare to the hydraulic system when it comes to raising the wheels off the deck. That aside , not all pitches are in need of a full lift. Its primary function is to Aid the drive and prevent rolling whilst in drive. The ability to level out when on site is an addition and a bonus only. Its fit will only allow for levelling out and not to maintain the Truck or to assist the removal of a wheel should you ever get a puncture.Had E&P for a while now. Had it on max in Spain and Lancashire this weekend. Pros are the usual long range leveling, roof draining, waste water draining and wheel changing. Remote great to use. Cons are cost and now and again auto won't do big angles. But manual is easy to use. See photo of this weekend. I don't think VB on its own would get anywhere near this angle. If you take into account suspension/wheel drop when they're off the ground, this would be a huge gap for VB to raise up to.
We've got semi air on rear but would go full air when we get a replacement MH in the future. We went for slightly longer springs on the front to facilitate the longer range rams.
I agree guys. Just a view that was all. I would love the E&P to be honest. I Just cannot afford both .I agree with everything you say. But I don't ever have to move pitch or site if it's not level.
You've also got to remember, the higher the lift, the higher you have to climb to get into the van, or worse, put the silver screen on, or open/close it.Personally.. I would rather change pitches than to be on a incline of 20 degrees or more
Kev![]()
I suppose you could always lower it like buses do for alighting passengers!You've also got to remember, the higher the lift, the higher you have to climb to get into the van, or worse, put the silver screen on, or open/close it.
I have the HPC system and once the engine is stopped you can release the hand brake and jacks will stay extended until restarted.. The E&P set up is I believe the same but I'm sure sombody will confirm.Can I ask whether it’s possible to use the E&P to level, then switch off the ignition and release the handbrake without the system retracting the jacks? The reason I ask is that the handbrake lever tends to get in the way of the revolving driver’s seat when the handbrake is on and I’d like to be able to lower the brake lever to give full mobility to the driver’s seat once the van is level.
Is that possible?
Not on ours. But I seem to remember someone on here mentioning a similar issue and having theirs configured differently. I hope they'll come on and explain, because I can't find the thread.Can I ask whether it’s possible to use the E&P to level, then switch off the ignition and release the handbrake without the system retracting the jacks? The reason I ask is that the handbrake lever tends to get in the way of the revolving driver’s seat when the handbrake is on and I’d like to be able to lower the brake lever to give full mobility to the driver’s seat once the van is level.
Is that possible?
We have and they are excellent, we added the remote app with weighing facility last year and this only adds to the experience, I took the van to a DVSA weighbridge and the hy4 system was more accurate due to the DVSA weighbridge going up in 10 kilo increments. Honestly they are probably the best thing we have added to the van.Has anyone tried the Al-Ko HY4 system. It seems a bit different with independent hydraulics for each wheel and I believe it can weigh the vehicle too, so that you can check your loading and axle loads.
Yes you can but you must have it on when you turn it back on or you will get a warning.Can I ask whether it’s possible to use the E&P to level, then switch off the ignition and release the handbrake without the system retracting the jacks? The reason I ask is that the handbrake lever tends to get in the way of the revolving driver’s seat when the handbrake is on and I’d like to be able to lower the brake lever to give full mobility to the driver’s seat once the van is level.
Is that possible?
Sorry but VB air assist or Active air for us . The VB system not only self levels but firms up when cornering . It Tilts to empty the grey water tank plus it can be used to either raise the front or rear end when draining off residual water from the roof .
See the Video and let it make up your mind.
The hydraulic system is brilliant dont get me wrong. However...Its only useful if stationary!!
Kev
Probably only for the Al-Ko chassis though?We have and they are excellent, we added the remote app with weighing facility last year and this only adds to the experience, I took the van to a DVSA weighbridge and the hy4 system was more accurate due to the DVSA weighbridge going up in 10 kilo increments. Honestly they are probably the best thing we have added to the van.
Just not feasible every time you want to get in and out.I suppose you could always lower it like buses do for alighting passengers!
The Tesa Autolift 4 does not require the ignition to be on, indeed you get a loud warning if you try and start the engine with the legs down. At £3500 fitted it is a very cost effective option. Comes with a remote control and has both automatic and manual modes, very easy to use.Can I ask whether it’s possible to use the E&P to level, then switch off the ignition and release the handbrake without the system retracting the jacks? The reason I ask is that the handbrake lever tends to get in the way of the revolving driver’s seat when the handbrake is on and I’d like to be able to lower the brake lever to give full mobility to the driver’s seat once the van is level.
Is that possible?
Sorry yes we have the Al-Ko chassis.Probably only for the Al-Ko chassis though?
I am not a German speaker/reader but I think this from the AL-KO site says the HY4 system can be fitted to the Ducato, Boxer and Jumper 250/290 chassis as well as AL-KO ones. It seems to mention others too.Probably only for the Al-Ko chassis though?
Unfortunately no. If you remove the ignition key, then let the hand brake off, all 4 rams retract instantly and harshly dropping the wheels back on to terra firma. It was quite frightening when it first happened.Can I ask whether it’s possible to use the E&P to level, then switch off the ignition and release the handbrake without the system retracting the jacks? The reason I ask is that the handbrake lever tends to get in the way of the revolving driver’s seat when the handbrake is on and I’d like to be able to lower the brake lever to give full mobility to the driver’s seat once the van is level.
Is that possible?
Pack a shotgun and German Shepherd if you’re staying overnight.We've had the Amplo system fitted by Towtal. Good kit all made (not assembled) in Italy. Towtal are the sole importers and are in daily contact with the factory. Good aftersales service and overnight stop available at their workshop. Free courtesy car as well.Also offer 5% discount to CAMC members. Recommended.
Ha ha! The main menace were the trains! But they stopped at 9.45pm and didn't restart until 6.45 am. Oh yes and the pigeons on the old Aynsley China factory buildings.Pack a shotgun and German Shepherd if you’re staying overnight.
Mine stays up if the ignition is off and the handbrake is off too, infact at the last mot we used the jacks to lift the back wheels off the ground so the mot guy could spin the rear wheels. How old is your installation? Mine was done last year so maybe they've changed how it works.Unfortunately no. If you remove the ignition key, then let the hand brake off, all 4 rams retract instantly and harshly dropping the wheels back on to terra firma. It was quite frightening when it first happened.
It also contradicts the claim that the system provides additional security i.e. wheels of the ground prevent the vehicle being driven away. Having said all that, we wouldn't be without it.
