Roof Box on a bike rack? (20 Viewers)
Jan 17, 2022
92
141
Scotland, UK
AutoSleeper Neuvo
Newbie!
Hey Gang - hoping someone has gone down this route before!
Context is that we’re going skiing in our motorhome (for the first time) - but it’s not a big van! An A-S Neuvo, it’s only 6m and has one relatively small under bench garage. There is a Fiamma Pro-C bike rack on the back, which I’ve switched to e-bike rails. I also have large car roof box. And finally, as we’re going for an extended period, it’s made sense to buy skis, rather than hire.
The cunning plan is to somehow mount the roof box onto the bike rack and transport the skis in it.
I did a bit of research and got confirmation some people have done this, but frustratingly short of detail! Having had a quick look, the weight is fine, the length is fine, but I think the box will be too wide to either sit on the horizontal rails or mount onto the vertical bars if I remove the rails.
Anyone have experience here?
Thnx,
Heeb
33,561
69,789
Pictures would help us help you! :giggle:
113
151
Southampton, UK
Roller Team T590
Hi Heeb, I’ve fitted a back box on my bike rack, in principle got to be the same, just add holes in right place & bolt on, I silicone sealed existing holes in box, works for me fine
222
951
tetbury
AutoTrail Expedition
Long time
Put the skis across the bike rack!
We had a Nuevo, it's not winterized, outside water will freeze, you will use alot of gas keeping warm! Avoid staying in high altitude sites unless spring skiing!
Most important thing is to weigh the van with all the kit onboard, you will probably find your back axle is well over weight!!!
Hope it all works out for you, wish my body was still up for it!!
H
Jan 17, 2022
92
141
Scotland, UK
AutoSleeper Neuvo
Newbie!
jwells thanks for the reply. In theory, our van has the Winterised pack. We’ve been out in sub-zero, but not extreme! Did you have water tank heating pads? Obviously still worried about exposed pipes freezing solid! Will be doing the bucket method with the waste. We’ve weighed ourselves with e-bikes on the rack and were on the wire, so yes, will be being careful there. Any other tips/warnings about skiing with the Neuvo greatly appreciated!
As to just putting the skis straight onto the rack, I’ve heard horror stories of how much road muck can make them rust/degrade.
H
Jan 17, 2022
92
141
Scotland, UK
AutoSleeper Neuvo
Newbie!
MalcMc what kind of backbox do you mean? And did you mount to the horizontal bike rails, or remove that and mount onto the vertical rails (as I’ve seen with a roof box)?
H
Jan 17, 2022
92
141
Scotland, UK
AutoSleeper Neuvo
Newbie!
IMG_0475.jpegIMG_0061.jpeg!
4,257
5,291
Market Rasen
Since 2003
Thnx,
Heeb
I use one of these
33,561
69,789
I'm trying to imagine what you mean by too wide. Do you mean it will stick out too far backwards, ie too deep?
Can you mount it with the back of the box facing the back of the MH with the 'hinge' on the side and the opening on the other side, ie as a door would open? You'd need to have straps/netting to keep the contents in place when you opened it but could possibly work.
122
414
Hampshire, UK
Weinsberg
How many pairs of skis? Can you not just put them in a ski bag inside the van to travel, then under the van when on site?
Or strap the ski bag to the folded bike rack, vertically?
I did once fit a Thule roof box vertically to a bike rack by bolting roof bars on the cycle rack and mounting the roof box on the roof bars. You could replace the bike carriers with roof bars on the outside part then mount the roof box on them.
