stevewagner
Great explanation but actually UK supply is referred as 230 volts since European harmonisation in 2003, although there has been no actual change in reality.That's why I usually put it in 'inverted commas'. 'Reverse polarity' is the term used by some people to refer to the reversal of the phase and neutral conductor in a single-phase AC mains supply. But everyone knows what is meant by it.
Of course those that know better will point out that one of the conductors (neutral) is permanently fixed at about zero volts with respect to earth. The other conductor (phase, aka line or live) has a voltage that varies sinusoidally between about 340V positive and 340V negative 50 times per second with respect to earth. The current also varies sinusoidally (alternates) from positive to negative 50 times per second, which is why it is called Alternating Current (AC). The root mean square average of a 340V peak-to-peak sinusoidal waveform is about 240V, which is why a single phase mains supply in the UK is referred to as '240V AC'.
