MisterB
- Feb 25, 2018
- 6,762
- 15,573
- Adria 670 SLT
- enough to know i shouldnt touch things i know nothing about ....
Thanks, I have a 300A Fogstar lithium. Using their App I can see it pulls around 140A when both the microwave and kettle are in at the same time. It has a max continuous discharge rate of 200 Amps, so should cope easily with what I expect to use at any one time ( hence the limiting of sockets supplied by the inverter to just three instead of all six on board sockets) in an attempt to ensure I don't exceed the max discharge rate. The app also has an over current discharge history so can keep an eye on that from time to time.Just make sure that the peak discharge rating of the batteries is not being exceeded. At 3kW you will be pulling around 230A out of the batteries assuming minimal voltage drop. I have 2 x 100ah and the max is 2 x 100A.
Aluminium, if that’s what your cables are, has roughly 50% higher resistance than copper. It does makes the length of the 12V run more important for a given CSA - but a useful test is to feel to see if they get hot. If they did not even get warm (which is OK) after a few minutes of hundreds of amps passing through I’d be a bit surprised at those sizes.
The cables are now 35mm2 copper as I have ditched the copper coated aluminium cables it came with.
Thanks for your comments/input, theyre helpful for me to double check my thinking!
