- Nov 30, 2009
- 6,553
- 157,945
- PVC the PUG
- Since 2009 with motorhomes several caravans then tents before that.
Hi @black9146 .....Sorry for the delay in getting back to you we are just back from a holiday in Scotland.
So...Welcome to the forum
Thanks for your comments and taking the time to read the build blog, glad you enjoyed it.
So glad your going to have a go at building your own van, if a Bricklayer can do it a Joiner certainly can
I originally wanted to use Vohringer boards but found it so hard to source them. It seemed unless you are a recognized converter the suppliers didn't want to deal with you. The Pug had (13) 8 x 4 sheets so you would think a supplier would be interested.
While trying to source Vohringer boards i came across one supplier who seemed to be up for supplying them, he promised 3 times to send out a colour sample....It never came so i just give up and went with the second best.
The ceiling boars came from www.magnummotorhomes.co.uk The board itself is around 3mm thick and has a textured finish which looks better and smooths out any ridges in the van roof. The ceiling was built up in layers, Firstly a 60mm wide strip of ply was stuck and screwed to the vans roof supporting ribs. This gave the required depth to take the insulation. Next a couple of 8 x 4 sheets of 6mm ply were stuck and screwed centrally down the length of the van. Then finally the board you are asking about was stuck using contact adhesive to the 6mm sheet.
Magnums also do a H section to join sheets together.
If I am honest i cant remember any teething problems but we did start using the van before it was fully complete so could adjust things along the way. Dont think i would change anything but have often thought the sink and oven could have swapped places. The sink would have been nice to have a work surface either side. Other than that its perfect for our type of Camping. We have just had our longest trip out yet at three weeks and have to say i am very happy with everything.... Building your own van gives you everything you want and need and nothing you dont
Good luck with you project and please post some pictures if you get the time.
Cheers.....Ralph
Cheers.....Ralph
